High pressure shower head?
I just installed a high pressure mixing valve and I want a great high pressure shower head. Think...firehose! Any suggestions?
Subscribed! I don't understand the newest rage, those "rain forest" shower heads that are like 50 old men with enlarged prostates tinkling on you...
Give me some pressure!
Unregistered
Any water-saving standard showerhead will flow water like crazy, after you take a drill bit to the internal orifice.
Move up in small incriments. It's easy to drill it out too far and get too much water flow. |
Unoffended by naked girls
Like this?
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
some of them just have like a rubber donut inside. all you have to do is take it out.
abit off center
What are you trying to remove?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Cobwebs. Sometimes I have to start a day after little or no sleep. A good shower invigorates me. My current shower just sprinkles like an old man peeing on a flat rock.
N-Gruppe doesn't exist
stop bathing on a flat rock
Ted '70 911T 3.0L "SKIPPY" R-Gruppe #477 '73 914 2.0L SOLD bye bye "lil SMOKEY" ![]() "Silence is Golden, but duct tape is SILVER.” other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L |
Buy a Moen. They have a rubber oring. Remove it and enjoy. I have done this on both at my house. When the ex left she complained for a year about her place. I just bought her 2 and did the same. It is in the neck and easy to see and remove.
2011 Wrangler Unlimited X |
1980 911 SC
i bought one from waterpick for $15. The best I used, better than the $100 jobbies. several settings and a strong pulsating massage.
Life's a Beach |
Try this... Hotel Showerheads - S-2252-AF . I've used them for years. The last one I bought had a removable water restriction device (which was promptly removed). Home Depot carried them the last time I checked.
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
Student of the obvious
Try Oxygenics. We've had one from their "Skin Care" line for years. My wife loves it as it's low flow, but high pressure so it'll get the shampoo out of her hair.
Oxygenics®- Super Charge Your Shower™
Lee Last edited by LeeH; 05-05-2010 at 12:24 PM.. |
Perhaps a hand-held shower hose with this attachment:
![]() For those hard-to-reach areas of your anatomy, choose from several with rotary heads. ![]() ....and for deep cleaning and stubborn deposits, this shower accessory should be quite effective: ![]() Sherwood |
Moses, go get a Hans Grohe (Club Master) and be done with it. I try and push for that model on all my showers designs and builts. If you take the restrictor out, you will loose some skin. I usually leave them on and it is more then good enough. Don't fart around with drilling them. I have not found any other shower hear that will out perform Hans Ghohe. Not cheap, about 100 bucks for that thing. You are in LA somewhere aren't you. You are welcolm to come and check out mine.
Jeff |
Amazon.com: KOHLER K-10284-CP Forte Multifunction Showerhead, Polished Chrome: Home Improvement
same as Holiday Inn Express. Best showerhead in all of my travels.
-mike |
I have a high flow showerhead too. It's great. Untill you realize the hot water is gone in five minutes.
'85 911. White - 53,000 miles bought 3-16-07. "Casper" '88 924S. Blue - 120k miles bought with 105k miles. '94 968 Coupe - White - 108,000 miles bought 9-28-17 '09 Cayman - Grey - bought 9-8-20 |
Senior Member
How pray tell would you know what its like being peed on by a 50 year old guy? Possibly TMI my friend...
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
There really isn't much difference is there.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
canna change law physics
When I was working in Puerto Rico, they had the low flow heads. The problem was the sound the shower would make at 4AM. I took a wrench to it and pulled the rubber flow restrictor. Lots of water, no horrible sounds. I'm sure my neighbors appreciated my efforts.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
JW Apostate
You might ask your plumber to attach a water pressure gauge on the outside of the house on a hose bib.
I seem to remember 80 psi as 'normal'. I forget. though. You may need to adjust or replace your water pressure regulator after the meter. KT
'74 914-6 2.6 SS #746 '01 Boxster |
