B58/732
BlueSkyJaunte's Avatar
GIYF:
High Pressure Shower Heads - Enjoy Your Showers Again! High Pressure Shower Head
ΜΟΛΩΝ ΛΑΒΕ
Old 05-05-2010, 03:58 PM
Slippery Slope Victim
NY65912's Avatar
Speakman.
We use them in hospital and institutional buildings. Yes, I am a plumber.
MikeČ
1985 M491
Old 05-05-2010, 05:11 PM
Formerly reformed
Originally Posted by trekkor View Post
You might attach a water pressure gauge on the outside of the house on a hose bib.
+1. Our house was set @ 55 psi when I checked it before putting in the soda fountain (carbonation can backflow if it's not set right vs. house pressure). I cranked it up to 75 and our showers are much, much better. The gauges cost about $10 and it's pretty simple to adjust- you just have to make sure you don't turn it up too high or scouring can destroy your pipes and appliances.
edit: Yes! The Speakman (is it Easyflow?) heads are awesome.
edit again: Anystream; that's it. Thank you, David
1968 911P (Paperweight)
Old 05-05-2010, 05:48 PM
As a liberator of restrictors in shower heads, its pretty much up to how the shower head looks if you want to pay a lot. Once you get the restrictor out, they all work much better then before Myself, I'm partial to Moens. The new plumbing codes are exhausting. I recently had a master bathroom added to our house the included a air-tub. It required a regulator that would not let the water get much above 100, no mater how you tried with the knobs. I paid the guy to remove it once the inspection was done.
Old 05-05-2010, 05:52 PM
david914's Avatar
The link I posted earlier is for the Speakman Anystream. You can dial in anything from high flow, low velocity to low flow, high velocity.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 05-05-2010, 06:33 PM
Senior Member
What can you do if your water pressure out of the city main line is 40 psi or so? Thats all we have where I live and would love to see 50 or higher.
Old 05-05-2010, 07:33 PM
Normal pressure should be above 60psi. I have put in baths that have around 50 at the end of the line with no regulator. The Hans Ghroe will still work wonders with only 50 psi. I turned the pressure up to 70 at my own home. All the hose bibs are about 120psi. I bypass the regulator because its going outside and I like to blast the local wild lives and keep the coons at bay. I am up in the hills and the pressure is at 120 or so.
Old 05-05-2010, 09:43 PM
Unregistered
sammyg2's Avatar
$100 for a showerhead? LOL, not in my house ....
Old 05-06-2010, 06:31 AM
Originally Posted by Moses View Post
I just installed a high pressure mixing valve and I want a great high flow showerhead. Think...firehose! Any suggestions?
I replaced the pre-installed shower head with WASSA, and unexpectedly it increased the shower flow to a level sufficient to meet my needs. This is not an uncomfortable shower intensity, it keeps me clean and strong enough to enter a pseudo-meditation state.
Old 12-03-2019, 05:59 PM
wdfifteen's Avatar
Any water-saving standard showerhead will flow water like crazy, after you take a drill bit to the internal orifice.
Move up in small incriments. It's easy to drill it out too far and get too much water flow.
I drilled mine to 3/8." Works like a charm. I'm not under the water long, so I don't use that much water. If MrSWD used it she'd drain the water heater.
Old 12-05-2019, 07:53 AM
Deschodt's Avatar
California is the specialist for those water saving heads... Some hotels have pressure but limited flow, so you get sandblasted instead of showered, to the point it's painful !
At my house we simply removed the extra donut/filter/blocker and it's perfect, I don't think you need a special shower head as much as investigating if there's a block there... Any non-castrated shower head will flow plenty with good water pressure.
Old 12-05-2019, 09:07 AM
As of last year, I think, we can't get a 1.6 GPM shower head anymore. They are restricted even more but they still can be had in rest of the country. The Hans Grohe Club Master is no longer available and many vendors will and can't ship it to CA.
Just find the restrictor, remove or drill it.
Old 12-05-2019, 10:55 AM
Originally Posted by LeeH View Post
My wife loves it as it's low flow, but high pressure so it'll get the shampoo out of her hair.
Riiight...
Old 12-05-2019, 11:35 AM
wdfifteen's Avatar
I'm sure she is "enjoying" squeaky clean hair.
Old 12-05-2019, 04:14 PM
