Moses's Avatar
High pressure shower head?
I just installed a high pressure mixing valve and I want a great high pressure shower head. Think...firehose! Any suggestions?
Old 05-05-2010, 10:33 AM
Subscribed! I don't understand the newest rage, those "rain forest" shower heads that are like 50 old men with enlarged prostates tinkling on you...
Give me some pressure!
Old 05-05-2010, 10:38 AM
Unregistered
sammyg2's Avatar
Any water-saving standard showerhead will flow water like crazy, after you take a drill bit to the internal orifice.
Move up in small incriments. It's easy to drill it out too far and get too much water flow.
Old 05-05-2010, 11:03 AM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Like this?
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 05-05-2010, 11:06 AM
hex9145's Avatar
some of them just have like a rubber donut inside. all you have to do is take it out.
Old 05-05-2010, 11:10 AM
abit off center
cgarr's Avatar
What are you trying to remove?
______________________
Craig
G2Performance
Old 05-05-2010, 11:14 AM
Moses's Avatar
Cobwebs. Sometimes I have to start a day after little or no sleep. A good shower invigorates me. My current shower just sprinkles like an old man peeing on a flat rock.
Old 05-05-2010, 11:20 AM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
stop bathing on a flat rock
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 05-05-2010, 11:30 AM
wreckersteve's Avatar
Buy a Moen. They have a rubber oring. Remove it and enjoy. I have done this on both at my house. When the ex left she complained for a year about her place. I just bought her 2 and did the same. It is in the neck and easy to see and remove.
2011 Wrangler Unlimited X
Old 05-05-2010, 11:31 AM
1980 911 SC
i bought one from waterpick for $15. The best I used, better than the $100 jobbies. several settings and a strong pulsating massage.
Life's a Beach
Old 05-05-2010, 12:09 PM
david914's Avatar
Try this... Hotel Showerheads - S-2252-AF . I've used them for years. The last one I bought had a removable water restriction device (which was promptly removed). Home Depot carried them the last time I checked.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 05-05-2010, 12:11 PM
Student of the obvious
LeeH's Avatar
Try Oxygenics. We've had one from their "Skin Care" line for years. My wife loves it as it's low flow, but high pressure so it'll get the shampoo out of her hair.
Oxygenics®- Super Charge Your Shower™
Lee
Old 05-05-2010, 12:20 PM
Perhaps a hand-held shower hose with this attachment:
For those hard-to-reach areas of your anatomy, choose from several with rotary heads.
....and for deep cleaning and stubborn deposits, this shower accessory should be quite effective:
Sherwood
Old 05-05-2010, 01:12 PM
Moses, go get a Hans Grohe (Club Master) and be done with it. I try and push for that model on all my showers designs and builts. If you take the restrictor out, you will loose some skin. I usually leave them on and it is more then good enough. Don't fart around with drilling them. I have not found any other shower hear that will out perform Hans Ghohe. Not cheap, about 100 bucks for that thing. You are in LA somewhere aren't you. You are welcolm to come and check out mine.
Jeff
Old 05-05-2010, 01:36 PM
Embraer's Avatar
Amazon.com: KOHLER K-10284-CP Forte Multifunction Showerhead, Polished Chrome: Home Improvement
same as Holiday Inn Express.
Best showerhead in all of my travels.
-mike
Old 05-05-2010, 02:02 PM
I have a high flow showerhead too. It's great. Untill you realize the hot water is gone in five minutes.
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 05-05-2010, 02:19 PM
Senior Member
How pray tell would you know what its like being peed on by a 50 year old guy? Possibly TMI my friend...
Old 05-05-2010, 03:30 PM
peppy's Avatar
No he said 50 old men peeing on him NOT a 50 year old man peeing on him.
There really isn't much difference is there.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 05-05-2010, 03:36 PM
canna change law physics
red-beard's Avatar
When I was working in Puerto Rico, they had the low flow heads. The problem was the sound the shower would make at 4AM. I took a wrench to it and pulled the rubber flow restrictor. Lots of water, no horrible sounds. I'm sure my neighbors appreciated my efforts.
James
Red-beard for President, 2020
Old 05-05-2010, 03:38 PM
JW Apostate
trekkor's Avatar
You might ask your plumber to attach a water pressure gauge on the outside of the house on a hose bib.
I seem to remember 80 psi as 'normal'. I forget. though.
You may need to adjust or replace your water pressure regulator after the meter.
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 05-05-2010, 03:39 PM
