How to safely remove the rings from an Audi decklid?
The rings on the decklid of my Audi have become quite pitted and in fact bubbly. I'd like to remove them, any tricks for doing this?
I also would like to know why they used such cheap plastic for these 'chromed parts', same for the front grill.
Champaign and Burgundy 3.2 (1986)
Ex-C4 91
Ex C4 93
A8 3.0 TDI
X5
Old 05-14-2010, 01:39 PM
Its just double sided sticky tape----careful use of a heat gun should do it.----depending on the colour,there may be unfaded markout on the paint.
Quality of the item is known as 'planned obsolescence'-----you are supposed to buy a later model car!
Old 05-14-2010, 01:44 PM
The Unsettler
stomachmonkey's Avatar
Little bit of warmth and fishing line.
Googone to get the residue.
"I want my two dollars"
"Brandon Won"
Old 05-14-2010, 01:48 PM
Run smooth, run fast
Heel n Toe's Avatar
Heat gun could be a bit difficult to keep from putting too much heat in play. Try it with a blow dryer first... with an attachment that pinches down the air flow to a smaller stream if possible.
Don't know if the rings were plastic, but last week on Ultimate Factories, they did an hour on the Audi R8... and showed the same doublesided sticky attachment method.
- John
Old 05-14-2010, 01:57 PM
gargles with Dom Perignon
Lazarro's Avatar
Dental floss and Goo-gone.
"If triangles' had a God, he would have 3 sides."
Old 05-14-2010, 02:42 PM
nostatic's Avatar
sawzall
Old 05-14-2010, 02:49 PM
PRO Motorsports
Tyson Schmidt's Avatar
I don't know, but you'll need a ring compressor to reinstall them.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 05-14-2010, 03:21 PM
Detached Member
Hugh R's Avatar
Dental floss works really well for that.
Hugh
Old 05-14-2010, 04:50 PM
Student of the obvious
LeeH's Avatar
Youtube... my favorite teacher.
Lee
Old 05-14-2010, 05:20 PM
Tx for the advice guys. Much appreciated.
Ex-C4 91
Ex C4 93
A8 3.0 TDI
X5
Old 05-14-2010, 11:32 PM
Plastic explosive.... its really the only way to make sure you get rid of all the junk parts on an audi....
Old 05-15-2010, 03:33 PM
Certified Pre-Owned
BGCarrera32's Avatar
Given that it's an Audi:
1) Obtain Bentley manual
2) Disconnect negative battery cable
3) Spend 45 minutes figuring out how to unsnap the front bumper
4) Remove 19 unnecessary plastic clips from some wiring harness
5) Surf the stupid AudiWorld forum
6) Print off technical posting on how to remove the emblem
'84 Carrera Coupe
Old 05-15-2010, 08:30 PM
MAGA
Tim Hancock's Avatar
You read my mind.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 05-16-2010, 07:35 AM
poorsche930's Avatar
7) When all else fails go get insulted by emo kids on vwvortex.com
You missed one!
Ryan
79 930..... among other fine German cars.
Old 05-16-2010, 11:57 AM
