jyl jyl is online now
jyl's Avatar
Welder For Home/Car Projects - MIG Or TIG?
All this talk of welding has me interested.
I've done a little TIG welding. Never MIG. For car and home projects, which is better - if you had to choose just one?
Old 05-23-2010, 11:09 AM
JW Apostate
trekkor's Avatar
The little 110 volt Lincoln MIG is great.
I've done lots of projects with it.
3 roll cages and loads of repairs on sheetmetal, etc.
It will weld up to 5/16" material.
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 05-23-2010, 11:21 AM
JW Apostate
trekkor's Avatar
Solid!
KT
'01 Boxster
Old 05-23-2010, 11:23 AM
MAGA
Tim Hancock's Avatar
Assuming you take the time to learn, TIG is the most versatile but obviously costs quite a bit more than a 110 wire welder.... You can weld anything with it. I would love a 180 + amp mig to speed up non critical larer welding projects, but my Miller tig has served me well over the last ten or so years welding chromoly aircraft tubing, auto repairs, stainless tubing, aluminum repairs, misc shop projects etc.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 05-23-2010, 04:15 PM
i want one of those...
Rufblackbird's Avatar
Location: formerly a grass shack in Hawaii, now Peoria, AZ
for car and home projects, definitely MIG. I LOVE TIG, but nothing beats the speed and versatility of having a MIG around the house. Imagine lying on the garage floor while trying to TIG a leaky exhaust in the back of the Vanagon, and having to hold the torch with one hand and pressing down the foot control with the other...not fun.
that said, if my garage was fully equipped with a lift or where I didn't have to be lying on my back welding, I'd weld everything with TIG.
Jeff
'72 911 T Targa widebody VTK #111385 http://www.911vtk.com
Old 05-23-2010, 10:55 PM
MAGA
I have a thumb-wheel on my tig torch.... It was nearly a necessity for welding in every position when welding up a 4130 tubing airplane fuselage. Mig is certainly MUCH easier to learn to weld with and obviously works pretty well for most general steel fabrication, but the OP asked the question "if you could choose just one"...... For me it would be TIG. Because I know I can get high quality welds if I need them on any type of material I find myself needing to weld whether mild steel, stainless or aluminum.
0% Liberal
Old 05-24-2010, 04:50 AM
(the shotguns)
berettafan's Avatar
Money no object i'd get a tricked out tig machine.
As it is i have a 110 miller mig and like it just fine.
Old 05-24-2010, 06:02 AM
LWJ LWJ is online now
John,
I am not a welder but I used to work for a company that sold welding supplies. The above answers are pretty valid. the one thing I would add is that if you get a 110V mig machine, make sure it has variable wire speed. Last I checked, Miller and Lincoln both had a machine with this feature. Some lesser machines don't. Word is, this makes all the difference in MIG.
Larry
Old 05-24-2010, 06:12 AM
Registered Abuser
MT930's Avatar
I too prefer TIG because of versatility (all metals). Longer learning curve
MIG is fast and easy. Great for mild steel. Most forgiving process.
Which ever process you choose buy a good brand name machine.
Miller
Lincoln
Esab
Used is Fine
Steer clear of the harborfreight stuff. It will just make you mad.
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 05-24-2010, 08:13 AM
Danimal16's Avatar
What about Mig for aluminum?
Dan
Old 05-24-2010, 08:19 AM
MAGA
Not ideal for high quality welds in non production settings.
0% Liberal
Old 05-24-2010, 08:54 AM
Danimal16's Avatar
Thanks Tim.
Dan
Old 05-24-2010, 09:33 AM
Tim, never heard of the thumb wheel for the TIG (Air Force Guard units don't have that fancy stuff ). How does it work?
If output is adjustable with your thumb I'd go with TIG!
Jeff
Old 05-24-2010, 07:52 PM
myamoto1's Avatar
John - you're welcome to come over to my house and try out my ESAB 250. If you have a portable project, bring it over or just bring some scrap (house is for sale, so scrap has been elminated).
Josh
85 M491 Coupe - "Fat Bastard"
Old 05-24-2010, 07:56 PM
jyl's Avatar
Thanks Josh. No need now -I've got to focus on getting the garage set up for making my kitchen cabs. The welder question is for the future plans - unless I see one on Craigslist . . .
Old 05-24-2010, 10:28 PM
We have a lincoln set up for aluminum and dedicated just to that... Its a BEOTCH... You have to have the metal perfectly clean with a CLEAN stainless brush... Then you have to hold your mouth just right and hope no flies in Zimbabwe fart while you are running the bead...
We are looking to buy a tig at some point FWIW....
Old 05-25-2010, 12:36 AM
Zeke's Avatar
That's what it does. The foot pedal is replaced with a thumb operated device allowing the user to weld lying down or on his knees, etc.
Old 05-25-2010, 08:30 AM
MAGA
Here is the one I have on my Miller Econotig. It takes a little bit to get used to, but once you do, you will likely use it all the time even for easy bench work.
0% Liberal
Old 05-25-2010, 09:32 AM
thanks guys, in that case I stand corrected, and would definitely go with TIG if it were just one machine.
Jeff
Old 05-25-2010, 02:55 PM
