Control Group
Tobra's Avatar
Thermosphere contraction
Oooh, mysterious unexplained atmospheric change. Perhaps synergistic effect of high
CO2 and low solar activity, but who knows, so many variables.
Scientists baffled by unusual upper atmosphere shrinkage - CNN.com
(CNN) -- An upper layer of Earth's atmosphere recently shrank so much that researchers are at a loss to adequately explain it, NASA said on Thursday.
The thermosphere, which blocks harmful ultraviolet rays, expands and contracts regularly due to the sun's activities. As carbon dioxide increases, it has a cooling effect at such high altitudes, which also contributes to the contraction.
But even these two factors aren't fully explaining the extraordinary contraction which, though unlikely to affect the weather, can affect the movement of satellites, researchers said.
"This is the biggest contraction of the thermosphere in at least 43 years," John Emmert of the Naval Research Lab was quoted as saying in NASA news report.
Emmert is the lead author of a paper announcing the finding in the June 19 issue of the journal Geophysical Research Letters.
"We cannot explain the abnormally low densities, which are about 30 percent lower" than from previous contractions, Emmert told CNN.com.
The thermosphere lies high above Earth's surface, close to where the atmosphere ends and space begins. It ranges in altitude from 55 miles (90km) to 370 miles (600km) above the ground -- the realm of meteors, auroras, space shuttles and the international space station.
This is the biggest contraction of the thermosphere in at least 43 years.
The thermosphere interacts strongly with the sun and hence is greatly influenced by the sun's solar activity, which occurs in cycles.
When solar activity is high, solar extreme ultraviolet rays warm and expand the thermosphere. When it's low, the opposite occurs.
The collapse occurred during what's known as a "solar minimum" from 2007 to 2009, during which the sun plunged into an unprecedented low of inactivity. Sun spots were scarce and solar flares were nonexistent, NASA reported.
Still, the collapse of the thermosphere was bigger than the sun's activity alone can explain.
Emmert suggests that the increasing amounts of carbon dioxide making its way into the upper atmosphere might have played a role in the anomaly.
Carbon dioxide acts as a coolant in the upper atmosphere, unlike in the lower atmosphere, shedding heat via infrared radiation. As carbon dioxide levels build up on Earth, it makes its way into the upper levels and magnifies the cooling action of the solar minimum, Emmert said.
As carbon dioxide gradually builds up, "we expect every solar minimum to be a little lower, and then this solar minimum comes along, but instead it's a lot lower. And that's pretty surprising," said Stanley Solomon, a senior scientist with the National Center for Atmospheric Research who wasn't directly involved in this research.
But, Emmert said, even taking into account the solar activity and carbon dioxide buildup doesn't fully account for this abnormal collapse.
Despite the puzzling anomaly, the collapse of the thermosphere is unlikely to have a direct effect on our daily lives, said Solomon.
"It's not going to affect the weather, or you won't be able to tell that this is going on by looking at the sky. It's not going to look any darker," he said.
But the contraction of the thermosphere can affect the drag on satellites and space junk orbiting at those levels.
"Debris that's up there stays up longer. The amount of orbital debris is a concern for space navigation. There is concern that space debris is building up," Emmert said.
The abnormal change in the thermosphere may also affect other layers of the atmosphere, and though less certain, can result in slight disruptions of satellite communications, including global-positioning system signals, Solomon said.
Emmert said there were still other possibilities unaccounted for that could have contributed to this phenomenon.
"It could be that we're underestimating the effects [of carbon dioxide] somehow. It could be because there were some physics that we're missing in the region of the atmosphere below the thermosphere, which quickly affects the thermosphere," he said.
The researchers say they will continue to monitor the upper atmosphere, which is already rebounding.
"So we're probably going to work in the next couple of years to try and unravel this," Emmert said.
Old 07-17-2010, 09:04 PM
Information Junky
island911's Avatar
A 'build up of carbon dioxide'? . . . our atm. is not even at 10% CO2 . .. not 1% . . .not 0.1% . . . but somewhere around an increase from 0.034% to maybe 0.038%CO2 in the earths atmosphere. --oh no. . . the CO2 levels are now (maybe) 0.004% atm extra.
Seriously, do people not know that plants work hard to scrub the air of CO2 as part of a carbon cycle? ...CO2 is plant food -- photosynthesis and all -- and there is not much of the stuff making up our atmosphere. (even with the large portion of decaying plant material, and the small percentage (un-natural) man makes.) ... less than 0.04% of our atm.
Yet the article repeats "carbon dioxide build up" . . . as if to say "be afraid . . be very afraid..we don't know how this is going to screw us, so be afraid if the build up."
Old 07-18-2010, 12:06 AM
Information Junky
island911's Avatar
So, essential, they are saying "The sky is falling! . . .and carbon dioxide increases are to blame"
again . ..
Old 07-18-2010, 11:37 AM
AutoBahned
RWebb's Avatar
That's an interesting tidbit, Tobra. Thx for posting it.
Too bad Mr. CO2 had to weigh in - the real issue of course is how sensitive various things are to CO2 increase. We are already losing certain plants as other plant types invade. The latter use a different type of CO2 metabolism and benefit from higher CO2 levels. The range expansion of some of these plants is a major effect on extinction risks for some bird species.
The oceans are also becoming more acidic, so shellfish and other organisms are having a hard time as they form their shells from a material that is highly sensitive to acidity.
re the Thermosphere, I hope this remains just a scientific curiosity and isn't a harbinger of some new problem...
here's some background for those interested
http://people.virginia.edu/~rej/MAE494/Part-3-07.pdf
Old 07-18-2010, 12:04 PM
Thanks you for the post.
Watch Salt Online Free
Old 07-18-2010, 08:41 PM
Such a very amazing link!
Old 07-18-2010, 08:46 PM
