Unregistered
sammyg2's Avatar
Originally Posted by Joeaksa View Post
You get to go stand in the corner. That would gut any value in the car and make worth squat.
If I had room in the garage and some extra $$ this would be mine... no question!
Even though it'd make it actually drivable and reliable?
Rip out all the lucas crap and replace it with delco, put a small block and a muncie tranny in it, and you've got a real car.
Call it a Lister if it makes you feel better.
Or, leave it like it is and stare at it and worship it, and be afraid to drive it more than a block because you know it'll leave you stranded.
My buddy in high school had a 12 cylinder E type. I used to sync his carbs for him. A couple times a week. That cable linkage was a thing of beauty
Electrical fire? no big deal, he carried gloves in the car at all times for that sort of thing. Just grab a handful of smoking wires and yank.
Then call me to hot-wire it so he could get it home.
If jaguar has installed a fire extinguisher under the dash as OEM, I'm sure the extinguisher would have spontaneously burst into flames.
Those cars are truly beautiful from an artistic point of view, but from an engineering viewpoint they are uglier than a Pontiac Aztec. IMHO, of course.
Old 10-22-2010, 08:53 AM
Old 10-22-2010, 08:55 AM
Unregistered
sammyg2's Avatar
Old 10-22-2010, 08:56 AM
Biggest tease in the car enthusiast world. Drop-dead gorgeous supermodel that has so many STD's you're afraid to drive her. You are the envy of all of your friends, but they have no idea what your life is like with her.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 10-22-2010, 09:09 AM
pwd72s's Avatar
The E type...a rolling phallic symbol. Never owned one, so no tips on mechanicals, etc...
Old 10-22-2010, 09:12 AM
Unregistered
sammyg2's Avatar
Gentlemen, That is as well stated as it can be. if he had thrown in a 928 "exotic" reference it would have been perfect.
Bravo, our work here is done.
Old 10-22-2010, 09:17 AM
I own an early E-Type ('61 OTS) and can confirm that its is truly a rolling beauty and stops people in their tracks even here in car jaded Southern California. I completely restored mine over 15 years so reliability has not been an issue (yet) and I upgraded areas such as the brakes (Wilwood Calipers) and the cooling (Cool Cat ally radiator and fan) comfort (coolmat cabin liner) so she is cool in LA traffic.
However, the ergonomics are 1950's, the Moss box is truly awful and its not that fast but she sounds beautiful and I feel truly blessed everytime I drive her. Women swoon and guys give you the thumbs up. An icon and short of divorce or monetary disaster she will not be sold.
Kevin
'72 Norton Commando,
'47 Sunbeam S7
'14 Tacoma
Old 10-22-2010, 10:08 AM
Detached Member
Hugh R's Avatar
If you're in a relatively dry climate, Lucas electricals aren't much of a problem. It helps to have a Lucas electrical book for things like adjusting the voltage regulator and setting the points on the SU fuel pumps, which you will never figure out without the book. With the book, they're pretty easy to adjust/calibrate.
Hugh
Old 10-22-2010, 10:18 AM
Zeke's Avatar
I worked in an indoor Jag dismantler in '65 and took dozens of E-types apart. The front subframe bolted to the monocoque firewall was a real nice piece. It held the motor and front suspension pick ups. After you removed the bonnet it was plain, simple and to the point.
And, of course the independent rear suspension and 3rd member that hot rodders have lusted after for years is another nice piece. Another sub assembly that fit neatly up in the monocoque tub with a few bolts. All in all, if it weren't for the Lucas, the car was indeed well engineered.
And, as mentioned by you and others, if you kept after it and kept it dry, it wasn't all that bad. I've had my share of old British cars and pretty good luck. Alas, they are cars for aficionados, not kludges.
Originally Posted by Hugh R View Post
"....setting the points on SU fuel pumps."
Man, the memories! You're right, no one would even consider that a fuel pump had contacts inside.
Old 10-22-2010, 11:59 AM
AutoBahned
RWebb's Avatar
... every emotional thing in you wants this car but logically it makes no sense.
that encapsulates everything I've ever heard about them.
- the design is older than the 911, and less modern, esp. for the suspension
- it has more torque ("drive" as Jenks put it) than a 356 or early 911, but...
I'll see if I can dig up some notes from Jenks et al. later this pm
Old 10-22-2010, 12:05 PM
Zeke's Avatar
I guess the argument there is that MacPhearson strut torsion bar suspension is better than the double wish bone with a TB, as well as more modern. Then in '90 the 911 got coil over suspension all around like an E-type had in the rear. Later on, the 911 got multi-link which is like a double wishbone to me.
No, I don't get that. I think the XKE was the head of the class for a long time.
Old 10-22-2010, 12:19 PM
David McLaughlin's Avatar
Today I drove the '74 that my boss is selling. I've always loved the e-type; getting behind the wheel was a big mistake. I just wish I had the money to buy it.
1974 Jaguar XKE Series III V12, 4 SPD Roadster: Nice driver quality car! White on blue with navy top. 80k miles. CLEAN title. Super clean underside (floors, rockers, quarters are all solid with none of the common rust on XKE's). The car was originally blue, but has a driver quality re-paint in white. Interior and top have little ware and are exceptionally clean. Fresh re-build on the carbs and clutch master. Runs, drives, and shifts smoothly. Very nice example of the last of the XKE's. Also comes with hard top. - $35,000 or B.O
1970 914/6 RustoMod
2015 Mercedes E400
Old 10-22-2010, 04:38 PM
Detached Member
Hugh R's Avatar
Its a frickin doorbell.
Hugh
Old 10-22-2010, 05:19 PM
ERH ERH is offline
OK, Lovely car and all that.
Can I politely ask?... Have you ever driven one?
No power steering! You may think that's OK going by what a 911 is like to drive but this thing will turn you into a body builder.
Try reverse parking one before you decide to buy.
Gearboxes are notoriously notchy and ancient in feel. Makes a 915 feel positively modern.
Although a properly rebuilt one is quite good. The problem is they're rarely properly rebuilt unless owned by a fanatic.
Really stay away... Run to the hills. I know how you feel every emotional thing in you wants this car but logically it makes no sense.
Now if I had a terminal disease then I probably would buy one.
Now that is more like it. That helps, but they have if not fixed the gearbox at least made it different .
History of the JT5 Transmission
The steering... I have driven but not owned the original..... have not driven this car.
Old 10-22-2010, 05:48 PM
ERH ERH is offline
Originally Posted by Laneco View Post
The first time I saw an E-type coupe was my undoing... I fell in love with cars on that day and have never changed. They may not be a "good" car for most people but they are a "great" car for certain people.
That particular one is so sexy it gives ME wood!
angela
err... that does not help at all ...
Old 10-22-2010, 05:49 PM
pwd72s's Avatar
Is it true that testosterone must be added to Lister fuel or they won't run properly?
Old 10-22-2010, 05:52 PM
Schumi's Avatar
If you took 15 inches out of the section of the car between the front wheels and the windshield, I might actually like the E-Type.
Flame on.
M
Old 10-22-2010, 06:41 PM
Shaun @ Tru6's Avatar
The Emperor's New Clothes
These cars are god-awful ugly with absolutely no sense of proportion and the only styling cue of note being the length.
Tru6 Restoration & Design
Old 10-22-2010, 06:57 PM
Jim Bremner's Avatar
In the mid to late 80's there was a Jag E type that ran around Long Beach that was pretty hotrodded up! It might have not had any mufflers. One night I'm driving my '66 Fairlane GT in the tunnel under the Long Beach Airports main runway and I HEAR the Jag coming up at about 120 mph. I cut the power of my Ford off so that I could hear the Jag run past !
Damn if my ex didn't sream as I was coasting the car in neutral with the engine off ( no power brakes or steering to worry about)
That car sounded so nice!
The straight six engine was produced almost as long as the small block chevy!
Old 10-22-2010, 08:44 PM
Registered Usurper
DARISC's Avatar
Flame on.
'82 SC RoW coupe
Old 10-22-2010, 09:56 PM
