Mike C's Avatar
Originally Posted by rick-l View Post
I have a tire that loses 2 psi per week. How do I find the leak? It is not the valve stem, new. Soapy water in the bead shows nothing. It started after the tire had been on about 2 years.
I was thinking of filling it with R134 and using an electronic leak detector but it is hard to get fittings that will allow that.
Had the same problem on the wifes RX 8. Took it to the dealer twice & they couldn't find a leak. I finally found it. The screw in valve stem was loose.
Tightened it up & solved the problem.
Old 12-27-2010, 06:51 PM
Driver
Noah930's Avatar
Originally Posted by speedracing944 View Post
Bathtub with dishwashing detergent. Submerge the tire or splash soapy water all over it. Look for bubbles.
One other note of caution: Just make sure the wife isn't home when you try this method.
Personally, I'd opt for the kiddie pool or soapy water in a spray bottle options.
1990 Black 964 C2 Targa
Old 12-28-2010, 07:02 AM
HarryD's Avatar
I have had a few slow leaks that were very difficult to find. On my last one, it took about 4-5 minutes after the tire was submerged before the leak was visible and even then it was a very small stream of bubbles.
While I know some of you have issues with Les, the two near my house seem to be on the ball and have yet to let me down. It was one of them that found the slow leak by being patient and looking closely.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-28-2010, 07:50 AM
