AutoBahned
RWebb's Avatar
nice start, gents but we need more of the classics, antiques...
Old 04-05-2011, 12:58 PM
beancounter
jwasbury's Avatar
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 04-05-2011, 01:44 PM
beancounter
jwasbury's Avatar
Jacob
Old 04-05-2011, 01:46 PM
beancounter
jwasbury's Avatar
Jacob
Old 04-05-2011, 01:55 PM
Jim Bremner's Avatar
Originally Posted by jwasbury View Post
MOM?
Old 04-05-2011, 01:59 PM
Thread Killer
Teutonics's Avatar
Allen
'85 911 Coupe
'75 BMW 2002
'02 Ducati Monster 900ie
'18 GMC Sierra Denali 6.2L 4wd
Old 04-05-2011, 02:18 PM
Eric Coffey's Avatar
the 999. one of the sexiest bikes ever made:
Did you mean to type that in green?
IMO the (Ducati) 999 is akin to the (Porsche) 996; A major step backwards in the design/looks department.
Now, the D16RR is a different story:
Old 04-05-2011, 03:07 PM
gtc gtc is offline
abides.
gtc's Avatar
Someone PM Kai and tell him to get in here with his 998R.
Graham
1984 Carrera Targa
Old 04-05-2011, 04:28 PM
I was hoping to see a few of yours RW.
My sole Italian is a ratty V65sp.
Jim
down to jap bikes that run and a dead Norton
Old 04-05-2011, 04:49 PM
Virginia Rocks!
VaSteve's Avatar
Why do people b*tch about doing valve adjustments on these bikes? In concept, isn't it similar to doing a valve adjust on a 911, except for laying on your back and 12 quarts of oil?
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 04-05-2011, 04:50 PM
Max Sluiter
Flieger's Avatar
Just don't drop a valve while you are adjusting the closer.
4V Desmo Adjustment - Ducati.ms - The Ultimate Ducati Forum
Old 04-05-2011, 05:12 PM
I see you
flatbutt's Avatar
Originally Posted by VINMAN View Post
You can always tell the single guys!..
well you guys got the good ones!
Old 04-05-2011, 06:57 PM
Wyvern's Avatar
Mine is a different "Beast" in the Duc family
Brian
Old 04-05-2011, 07:01 PM
It's not even close to being the same process. There are no adjustment screws - clearances are set by shims. The rocker arms must be removed to change out the shims. The tank, seat, and fairings must be removed before the rocker covers can be removed. On some models, the rear upper shock mount has to come loose as well, so the bike has to be supported by something other than the swing arm in back. Oh, and that horizontal (front) cylinder pipe? It's right where you want to put the floor jack to do that. It's a lot more involved than doing a 911.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 04-05-2011, 07:08 PM
beancounter
jwasbury's Avatar
Actually the adjustment on a 2V duc is pretty easy. On the early monster you only need to remove the seat to gain access to the valve covers. The rocker arm does not need to be removed, but you must slide it aside to change out the shim. You just pry off the spring clip that keeps the rocker centered on its shaft. Closing shims are more difficult, but they've never needed adjusting on my bike (30k miles). The nice thing about the Ducati desmo valve train is that the lack of heavy return springs means that adjustments are seldom necessary. My bike needed a few adjustments in the 1st 10k miles or so, but none in the last 20k.
4v heads are a different story as I believe camshafts need to come out to change shims.
Jacob
Old 04-05-2011, 07:26 PM
I've found the same thing on my Super Sport (oh, and there is a lot more crap in the way on these than on Monsters) - after an initial adjustment right after I bought it, I've put over 30,000 miles on it with no further adjustments needed. I check it every year (along with replacing the belts - cheap insurance), but they are always fine. So, my $250 shim kit just sits...
Jeff
'72 911T 3.0 MFI
Old 04-05-2011, 08:04 PM
Max Sluiter
Flieger's Avatar
I was amazed when I first saw that thread on the Ducati forums.
Old 04-05-2011, 09:27 PM
Bill Douglas's Avatar
Duh, silly ole me, it's a moto guzzi.
Old 04-05-2011, 10:11 PM
Max Sluiter
Flieger's Avatar
Guzzis are righteous, too, their just not a Desmo. My hierarchy is 1. Ducati Bevel 2. BMW HP2 3. BMW boxer- air cooled, shaft drive, almost a Porsche 4. Ducati 748-996 series 5. Ducati 1198R
Old 04-05-2011, 11:31 PM
cnielsen's Avatar
Well it's a Duc frame and tank
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 04-05-2011, 11:35 PM
