AutoBahned
RWebb's Avatar
Screen Display Issues - hardware? software? appl. software?
Firefox is messed up pretty bad (shown on the RH side below) - note lack of all the gray boxes. Other sites are even worse.
Yet, Chrome (on the left) seems to work fine.
Yet again, MS Outlook seems messed up a little bit (as tho it is running in some sort of reduced resolution or low color bit mode).
other apps seem ok - Word, Excel, iTunes...
I can't seem to find anything in the Firefox Options that is wrong (and the secret squirrel, hidden options on a web page looking thingie are beyond my ability to decipher).
Old 05-17-2011, 05:42 PM
abit off center
cgarr's Avatar
LOL not again! go find an 8 yo and have him fix this thing once and for all!
______________________
Craig
G2Performance
Old 05-17-2011, 05:48 PM
winter-hater club member
nynor's Avatar
which version of firefox?
"COOL PRIUS!" - Nobody Ever
Old 05-17-2011, 05:56 PM
nynor's Avatar
Pages not loading correctly in Firefox - Geeks to Go Forums
see post 4.
Old 05-17-2011, 06:02 PM
nynor's Avatar
bollocks, double post.
AutoBahned
RWebb's Avatar
I am looking at your profile link now...
Old 05-17-2011, 06:04 PM
AutoBahned
RWebb's Avatar
nope - not a profile issue
Old 05-17-2011, 08:06 PM
jeffgrant's Avatar
You seem to have ad-block installed and active on the forums. It looks like the client-side javascript/CSS files (that do a lot of the layout work) are not being loaded properly.
I'd disable adblock for the site and try again.
If that doesn't work, try a force-reload (ctrl-shift-R) to see if that fixes it, or clear your cache and reload.
$0.02
Old 05-17-2011, 08:13 PM
AutoBahned
RWebb's Avatar
will try - it used to work fine until...
wouldn't starting mozilla in safe mode disable the ad-block?? it looked just the same when I did that
Old 05-17-2011, 08:17 PM
nynor's Avatar
perhaps the java settings in the options\content are disabled. its not a hardware issue. perhaps java needs to be reinstalled.
nynor's Avatar
until?
Old 05-17-2011, 08:18 PM
AutoBahned
RWebb's Avatar
until it all started -- a few hours ago or maybe it was yesterday
will try to re-install java
Ctl-shift-R while viewing this thread did not change anything
jeffgrant's Avatar
Java has NOTHING to do with it... Java isn't being used at all.
Javascript is NOT Java.
Old 05-17-2011, 08:19 PM
nynor's Avatar
fine. but there is a javascript enable box where i said to look. hang on, i'll disable it and see what things look like.
Old 05-17-2011, 08:21 PM
AutoBahned
RWebb's Avatar
javascript disabled
block pop ups disabled
I'll restart Firefox to see if it needs that...
jeffgrant's Avatar
Did you clear your cache?
Old 05-17-2011, 08:22 PM
AutoBahned
RWebb's Avatar
nope; no change
nynor's Avatar
javascript disabled changed nothing. interesting.
Old 05-17-2011, 08:24 PM
AutoBahned
RWebb's Avatar
I went to the Add-Ons menu to see if there was a popup blocker installed - did not see one, tho I know I used to have one; maybe it did not survive the new computer or upgrad to Ffox 4
BUT... I did note that the buttons on the plugins "page" or menu are messed up - they have two line drawings or outlines around them, and are not colored.
that seems not to be on the internet but inside Firefox...???
Old 05-17-2011, 08:25 PM
jeffgrant's Avatar
See if you can manually download this file: http://forums.pelicanparts.com/clientscript/vbulletin_important.css?v=387
That is the main file that determines the layout of the site. Odds are it's been corrupted in some manner, and is cached in your system.
And I run with JS disabled on here, and it works fine.
Old 05-17-2011, 08:26 PM
