AutoBahned
Screen Display Issues - hardware? software? appl. software?
Firefox is messed up pretty bad (shown on the RH side below) - note lack of all the gray boxes. Other sites are even worse.
Yet, Chrome (on the left) seems to work fine. Yet again, MS Outlook seems messed up a little bit (as tho it is running in some sort of reduced resolution or low color bit mode). other apps seem ok - Word, Excel, iTunes... ![]() I can't seem to find anything in the Firefox Options that is wrong (and the secret squirrel, hidden options on a web page looking thingie are beyond my ability to decipher). |
abit off center
LOL not again! go find an 8 yo and have him fix this thing once and for all!
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
winter-hater club member
which version of firefox?
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
bollocks, double post.
AutoBahned
4.0.1
I am looking at your profile link now... Thanks |
AutoBahned
nope - not a profile issue
You seem to have ad-block installed and active on the forums. It looks like the client-side javascript/CSS files (that do a lot of the layout work) are not being loaded properly.
I'd disable adblock for the site and try again. If that doesn't work, try a force-reload (ctrl-shift-R) to see if that fixes it, or clear your cache and reload. $0.02 |
AutoBahned
will try - it used to work fine until...
wouldn't starting mozilla in safe mode disable the ad-block?? it looked just the same when I did that |
perhaps the java settings in the options\content are disabled. its not a hardware issue. perhaps java needs to be reinstalled.
until?
AutoBahned
until it all started -- a few hours ago or maybe it was yesterday
will try to re-install java Ctl-shift-R while viewing this thread did not change anything |
Java has NOTHING to do with it... Java isn't being used at all.
Javascript is NOT Java. |
fine. but there is a javascript enable box where i said to look. hang on, i'll disable it and see what things look like.
AutoBahned
javascript disabled
block pop ups disabled I'll restart Firefox to see if it needs that... |
Did you clear your cache?
AutoBahned
nope; no change
javascript disabled changed nothing. interesting.
AutoBahned
I went to the Add-Ons menu to see if there was a popup blocker installed - did not see one, tho I know I used to have one; maybe it did not survive the new computer or upgrad to Ffox 4
BUT... I did note that the buttons on the plugins "page" or menu are messed up - they have two line drawings or outlines around them, and are not colored. that seems not to be on the internet but inside Firefox...??? |
See if you can manually download this file: http://forums.pelicanparts.com/clientscript/vbulletin_important.css?v=387
That is the main file that determines the layout of the site. Odds are it's been corrupted in some manner, and is cached in your system. And I run with JS disabled on here, and it works fine. |
