-   -   Semi acoustic guitar help, please. (http://forums.pelicanparts.com/showthread.php?t=612404)
Stephen 325TDS 06-05-2011 03:32 PM
When my son tries to play his guitar through an amp (a known working amp, with a working lead), it doesn't, err .... amplify! I unscrewed the little equaliser bit and replaced the battery. 'still didn't work.
I checked the wires that ran from that item to where the lead from the guitar (to the amp) gets attached, and they seem OK.
Does anyone know how I can test this bit? Can a replacement be readily sourced? What is the correct name for the bit/s about which I'm talking?
He wants to replace the guitar - I said that I don't replace my car everytime it needs a bit of TLC! (He's an end-of-1st-year university student, and is secretly hoping (as I see it) that the bank of mum and dad will spring to the rescue).
So any advice will be gratefully received. TIA.
Stephen
WolfeMacleod 06-05-2011 03:35 PM
It's possible that the Piezoelectric pickup isn't piezoelectricing.
I assume it's turned on?
Dan Himan 06-05-2011 05:11 PM
Start with the Instrument cord, then the cord plug in the guitar. They are the first to go. Especially if it was a used guitar, with drinking players stepping on the cord will in use. A little solder if bad. Check pick up wiring and signal.
stomachmonkey 06-05-2011 06:20 PM
Are the strings nylon (gut).
targa911S 06-06-2011 05:33 AM
Now THAT'S funny.
My "guess" would be the cable or the jack on the amp or guitar.
targa911S 06-06-2011 05:34 AM
I think son may have disabled it so you can buy that new Gibson ES 335 for him.
Stephen 325TDS 06-07-2011 02:46 PM
Thanks for the replies, folks. I'll try to sort it.
Stephen
