Semi acoustic guitar help, please.
When my son tries to play his guitar through an amp (a known working amp, with a working lead), it doesn't, err .... amplify! I unscrewed the little equaliser bit and replaced the battery. 'still didn't work.
I checked the wires that ran from that item to where the lead from the guitar (to the amp) gets attached, and they seem OK. Does anyone know how I can test this bit? Can a replacement be readily sourced? What is the correct name for the bit/s about which I'm talking? He wants to replace the guitar - I said that I don't replace my car everytime it needs a bit of TLC! (He's an end-of-1st-year university student, and is secretly hoping (as I see it) that the bank of mum and dad will spring to the rescue). So any advice will be gratefully received. TIA. Stephen
E30 318i ................. Gone. E36 325 tds ............. Gone. E39 525d ................. Gone. E39 535i .................. Resting Panamera 3.0 diesel ... Daily driver |
It's possible that the Piezoelectric pickup isn't piezoelectricing.
I assume it's turned on?
'85 911. White - 53,000 miles bought 3-16-07. "Casper" '88 924S. Blue - 120k miles bought with 105k miles. '94 968 Coupe - White - 108,000 miles bought 9-28-17 '09 Cayman - Grey - bought 9-8-20 |
SLED GUITARIST
Start with the Instrument cord, then the cord plug in the guitar. They are the first to go. Especially if it was a used guitar, with drinking players stepping on the cord will in use. A little solder if bad. Check pick up wiring and signal.
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2 1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan 1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
The Unsettler
Are the strings nylon (gut).
Double Trouble
Double Trouble
I think son may have disabled it so you can buy that new Gibson ES 335 for him.
Thanks for the replies, folks. I'll try to sort it.
Stephen
