1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
One point!! Failed by ONE point
Effin smog nazis failed my truck for being one friggen point over the limit. I just rebuilt the engine, it's running perfect but at 25mph it emits 35 HCs instead of 34. How pissed am I?
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 06-08-2011, 12:20 PM
abit off center
cgarr's Avatar
How accurate is their equipment?
______________________
Craig
G2Performance
Old 06-08-2011, 12:44 PM
The Unsettler
stomachmonkey's Avatar
Run the tank as low as you can, add a couple bottles of dry gas then put in only enough premium as needed to get it to the inspection station and run the tests. Idea is to get it to run on as much alcohol as you can.
Friend of mine who owns a shop told me that a bunch of years back when my car failed, worked like a charm.
"I want my two dollars"
"Brandon Won"
Old 06-08-2011, 12:55 PM
Used to be Singpilot...
Location: Sioux Falls, SD is what the reg says on the bus.
Get a haircut before going in to the test station.
Old 06-08-2011, 12:59 PM
Canucks Fan
close only counts in hand grenades
Old 06-08-2011, 01:01 PM
Unregistered
sammyg2's Avatar
Regular unleaded gas burns cleaner than premium during smog tests ................
Old 06-08-2011, 01:05 PM
Would it make you feel better if you failed by several points?
Old 06-08-2011, 01:57 PM
& horsehoes
Old 06-08-2011, 01:58 PM
& horsehoes
and atom bombs.
Old 06-08-2011, 02:01 PM
Banned
Really?
Are you sure?
Old 06-08-2011, 02:11 PM
...u still have sniffer emissions?
run some e85 in there.
Old 06-08-2011, 02:28 PM
Banned
As we speak, a guy in India is throwing a ball of plastic bags on a fire to keep warm. Oh wait, make that 1,000,000 guys.
Old 06-08-2011, 03:23 PM
Control Group
Tobra's Avatar
and atom bombs.
and government works
if the coil or distributor is a bit tired, you can get elevated HC on the sniffer, seen old plug wires do that too
You could always just pretend you only speak Spanish and don't have any license, insurance or registration, then they would just let you go. What color are your eyes and hair?
Old 06-08-2011, 03:39 PM
disband
juanbenae's Avatar
Really?
Are you sure?
yeah, thats what ive heard. the higher octane takes more heat to burn effective like so easier burn less do-do with lower octane.
Old 06-08-2011, 03:43 PM
one of gods prototypes
bell's Avatar
maybe the problem isn't the truck but the state you live in.........
Brought to you by Carl's Jr.
Old 06-08-2011, 04:44 PM
High HCss can be caused by fuel contaminated engine oil. .A rebuilt engine often lets more fuel past it,s unseated rings and add some fuel to the oil. The PCV system will suck up the fumes and increase unburned HC in the tailpipe. Small amounts can make enough difference to fail . A good long hot highway run will burn off most as will an oil change (smell the dipstick and change the oil if you smell any fuel).
Timing off a couple deg. either way will also affect HC.
If your HC was high caused by timing then your NOx would likely be on the low end of acceptable.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Florida should bring back etesting. I have a winter home in Tarpon Springs Fl. Florida has more than it,s fair share of "stinky" old cars.
1995 993 coupe
2012 Boss 302
Old 06-08-2011, 04:47 PM
Control Group
Tobra's Avatar
It may not pass until after your first oil change if motor is freshly rebuilt
Old 06-08-2011, 05:04 PM
bell's Avatar
i have to saw i see a hell of alot LESS smokey/smelly cars in florida than the previous 30 years in ohio.....who has e-check.......what does canada test for?
Old 06-08-2011, 05:12 PM
Ontario tests vehicles on a dyno at idle and 25mph . Sniffs 3 gases HC,Nox and CO Plus gas tank cap seal is verified.Exhaust systems are supposed to be leakfree to be able to be tested. Vehicles are tested every other year . No testing on pre 1988 cars but catalysts and other equipment can,t legally be removed /disabled. A gross polluter (oil burner cloud) can be stopped by the police and ordered off the road until repaired but that seldom happens. There is a $400 repair limit for a failed car.Taxis and commercial are also tested but there is no cap on repair costs.. There are fewer old cars still on the road here than Florida as our cars are subjected to winter road salt.Some norther counties are not tested presumably because of small numbers of cars. More travel by snowmobile you know
1995 993 coupe
2012 Boss 302
Old 06-08-2011, 05:23 PM
