What cars can I pull an electric vacuum pump from?
I need a vacuum pump to help out the braking system on one of my vehicles that doesn't make enough vacuum. I see in the below link that passats have them...not sure why but that doesn't matter. Do you know where it would be on a passat? What other vehicles have them and where are they under the hood. I might just go to a bone yard tomorrow
I'm with Bill
Why are you low on vac?
Electrical problems on a pick-up will do that to a guy- 1990C4S |
Well I can't say if I'm low but I want to try a little more and see if that helps or whether the truck ate another booster.
I'm with Bill
Just put a vac gauge in the line going to the booster. If you have around 20 inches you are good and the truck ate another one.
Ok good tip. I guess its most wise to do that. I know if I let it idle for a while it will make good vacuum (its a diesel with a mechanical vac pump) but usually I have to pick up on the pedal after pushing it down. Everything in the system is new.
You do not have permissi
"Vacuum takes a while to build up"? Hmm.
Rings not seating? Could the PCV or other check valve do this? Check another manifold vac source while cold. |
I'm with Bill
A diesel doesn't build vac from the engine, so it has a separate pump. Fords are famous for having the diaphragm in the pump fail, it is belt driven
my 79 300d has one.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
The vacuum canisters are really small and designed for carbs...I already bought one.
The stock pump is a vane ppm I believe so I doubt it can wear out in my lifetime but I don't think it was ever that good. Where under the hood of an old Benz would I find the electric vac pump? |
Sorry, I missed the big "electric" in the post title. Mine is mechanical. Back in the day i got one from a speed shop, I had a 69 GTO with a 400 and a really lumpy cam.
Ford diesel 4x4 trucks have them...
If you have a power steering pump ,why not switch the brake booster to "hydroboost" ? Leave the weak vac pump for the HVAC controls.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
Hydroboost is another thing thats on my mind. For now it seems cheapest to 1. test my current vac pump output; 2. install a reservoir if I can find one with large hoses instead of carb hoses; and 3. install a junkyard vacuum pump so long as I can find out if they ever shut off via a vac switch or just keep running?
