2009 up burb in lt trim....that way u get the limited slip and
6 speed. |
The locking rear diff (not exactly limited slip, but that's splitting hairs) has ALWAYS been an option, in any trim level
I love you guys outside this forum ![]() -Eric |
Now in 993 land ...
- Blown Transmission at 120k (overdrive) - Needs a timing belt ever 90k - $1500+ - Undersized brakes warp rotors and work poorly - need upgrade to later model - Rear door handle breaks every 2 years - Stock CD changer broken - Blinker / headlight switch broken - Radiator leak - Utter gas hog, never over 15 mpg - about 10-12 in town I realize it is over 10 years old now and others may do worse, but there are some $$$ on my list above that I experienced with that great Toyota quality. G |
-Mat 78 911SC |
In Eric I trust...trust me.
1996 FJ80. |
Did you get the memo?
I'll pile on some of the previous points made.
The Armada is down a few MPG from the competition, in our 2wd model the best I ever saw was 20 on the highway, normal was more like 18. Realistically the best you'll probably see in any full sized SUV is 20 MPG, so I was fine with it. The new bodystyle Suburban is surprisingly nice to drive, other than being somewhat underpowered (as Eric addressed) it really feels like a smaller SUV. I had a rental for over a week and got 20 MPG on the highway. Conversely I agree with Paul on the limitations as the interior ergonomics are just ok, materials are just ok (but far improved from previous models), interior styling is lacking, and it is missing some of the thoughtful touches of other models. For example, the 2nd row seat flip mechanism for 3rd row access is clunky and difficult, my Armada was a single lever and easy enough for my 5 year old to do alone. It also does not have a fold flat 3rd row seat, less of a problem because it's so big back there. The Expedition with a 5.4 is terrible, the lack of power borders on unsafe. They also have a spongy ride and LOTS of body roll. I would rate the interior as worse than the GM products. We drove multiple years and examples of the Expedition, I wanted to like it because they are one of the cheaper options. We didn't test drive the Navigator because my wife and I hated the bling styling, if you're interested in them do some research on the air suspension, in the older models it was a common and expensive failure. I did quite a few miles in a rental Durango (new bodystyle) and found it to be generally pleasant. Good ride quality, hugely improved interior, and overall nice to drive. The 3rd row seats are pretty small, definitely not adult sized.
‘07 Mazda RX8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc Last edited by onewhippedpuppy; 08-09-2012 at 10:40 AM.. |
I have 2004 Sequoia and love it. Have used the 4wheel drive in the snow when the only car on the road. Take many trips fully loaded with dogs, kids and gear. My fiance had a 2006 Tahoe bought new. It had many problems but was a comfortable ride. Electrical issues include doors locks. Metal chunks in oil during changes. Steering column knocking for which GM made a silicon fix kit but did not warranty. Leather worn in two years. Keep a watch at GM trucks/SUVS and see how many have a front running light out. We replaced three in two years same side. And was out again when we sold it.
OMG u r kidding! How dare a $4 filament bulb (that's how much the exact AC Delco 4114 bulb costs through a GM dealer, and they come with a one year warranty) in use anytime the headlights aren't on burn out so often. That's shoddy quality right there! You mean you went through $16 in bulbs in two years!!???
In my experience, the 6.2L does about the same as the 5.3L in most real-world conditions.....unless you use that power with a heavy right foot
Here's a 2004 Sequoia owner complaining that he blows bulbs all the time: Headlamps Keep Blowing.. Want To Install Hid Kit Soon.. Toyota's not infallible. GM is not infallible. They both build complex machines. Both have built good ones. Both have built bad ones. YMMV
We've narrowed our search to the burb or the LR3. The only thing that sways me more towards the burb is the issue with some LR3s having a differential failure. Seems some had a coating that would delaminate and destoy bearings. Other than that I REALLY want the LR3. If I found one that has already had the update we'll end up with it.
Dept store Quartermaster
Cornpoppin' Pony Soldier |
Banned
Well, from working with GM during that era (the GMT800 platform) I can tell you that a LOT of the problem stems from incorrect replacement bulbs. Note the AC Delco 4114 bulb I referenced earlier? It is a glass-base bulb. It is exactly the same style and wattage as a clear 3157 turn signal bulb (plastic base). MANY early afermarket parts guides spec'd the 3157 as the replacement bulb because it was the correct connection-style, size, and wattage. In other words, it plugged in and lit up. Trouble is, a turn signal bulb is used infrequently and intermittently. It doesn't have the chance to get hot. When used as a DRL, it gets so hot that the plastic partially melts and the bulb fails. Not the filament, the base. So using the incorrect 3157 bulb may cause a much shorter life span than the "correct" 4114 bulb. Still to this day you can walk into some Wal-Mart, NAPA, or Autozone and look at their bulb guide and see the 3157 listed. GM's thought here stemmed from what had been common practice to run DRLs as a lower-current run through the high-beams of the headlights. That was causing premature headlight failure and GM thought by switching to a dedicated light it would be safer than risking running with no headlight. And since headlight bulbs are $10-20 versus $4 for the correct DRL bulb, it would be a benefit to their customers. So shame on GM for adding the cost of having a separate DRL. And shame on them for allowing it to be confused with the wrong bulb by the aftermarket, by clueless morons who will later blame the truck itself. Mercedes-Benz, Toyota, and VW have all had similar issues with "almost-right" bulbs being used in the aftemarket and making problems for the manufacturer. But it's GM's fault.... [/rant]
This is not to say GM doesn't have serious quality and design issues...
And we know how you feel about GM....
To be fair (to me) I've owned dozens of GM vehicles and several were just fine. I also manufactured components for domestic and import vehicles for 20+years...yes there IS a difference and it's not insignificant.
Past tense? What year did that stop?
