AutoBahned
RWebb's Avatar
weatherproof electrical crimp on connectors
e.g Fast on types
are the weatherproof connectors any better (less likely to corrode) than just crimping on a regular terminal and then using heat shrink tubing over it?
Old 02-27-2013, 01:36 PM
1966 - 912 - SOLD
lane912's Avatar
found this product a while back and have found it to be superior to the crimp on conector-
it is reuseable-
weather tight nodel also-
Motorcycle Parts, Motorcycle Accessories – PhatPerfomanceParts.com
i was too tired to be pretty last night!
Old 02-27-2013, 02:15 PM
gt350mike's Avatar
I used to sell Molex and when I toured the factory, I asked for a few samples of their "Perma-Seal" connectors. It's essentially a connector insulated with heat-shrink tubing. Not sure if you want to go through the trouble of ordering it from Mouser (my recommendation) or Newark but if you have the need for a solid connector, look no further.
Perma-Seal
If you're really OCD on weather-proof connectors, check out this link:
Delphi Connection Systems e-Catalog Landing Page
2015 GLK (Momma's ride)
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 02-27-2013, 02:45 PM
1966 - 912 - SOLD
lane912's Avatar
oh here is the website I was looking for-
Posi-Lock(R) - The Best Connectors You'll Ever Use!
this is the weather tite option-- Posi-Tite- Watertite Connector
great product, the tap conector is fabulous-
mill-spec
Old 02-27-2013, 03:08 PM
there is also crimp connectors made for underwater connections, I have used them on submergable well pump connections, they work great, when you crimp them they ooze out some kind of sealer. You can get them where they sell welll supplies.
Old 02-27-2013, 05:48 PM
Is this for the Vanagon starter? Would heat not be the bigger concern? Application info would be helpful.
Old 02-27-2013, 05:52 PM
I think they have a silicone grease in them.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 02-27-2013, 06:58 PM
I built all my boats with terminals made by Ancor(now marinco), tin plated
The trick is the inside of the insulator is coated with hot glue adhesive.
After you crimp, heat, then you have a fully sealed connection.
I have had things pull so hard that the ring of the terminal broke and the wire never pulled out of the crimp.
Adhesive Lined Heat Shrink Ring Terminals | Marinco
http://www.marinco.com/productline/adhesive-lined-heat-shrink
I think 3M makes them also (3M Scotchlock Terminals ) but I don't think they are tin plated.
1987 Carrera
Old 02-27-2013, 09:50 PM
AutoBahned
RWebb's Avatar
Vanagon fuel pump - but curious (yellow) in general
Old 02-27-2013, 11:04 PM
DanielDudley's Avatar
Adhesive Lined Heat Shrink | Marinco
That sounds impressive.
Old 03-01-2013, 02:15 AM
Wandered off somewhere...
Drdogface's Avatar
Boy...that pun goes way back
I'm glad to see all these products as well....good to know.
Mark...
Porsche Boxster S
2012 Jeep Wrangler Rubicon..Crush Orange
Old 03-01-2013, 06:10 AM
pete3799's Avatar
I've been using these for years.
https://www.theelectricaldepot.com/pdf/scotchlok/3M%20314%20Scotchlok.pdf
Pete
79 911SC RoW
Old 03-01-2013, 07:10 AM
mill-spec
I believe these are the connectors that come with the JWest headlight relay kit?
They are very good connectors.
Old 03-01-2013, 11:11 AM
AutoBahned
RWebb's Avatar
I am curious yellow on the positive lead; but curious blue on the negative....
Now, I went to every FLAPS but NAPA in town and could not find any of the nice ones posted above; also went to a local electronics store and a good old-time hardware store - same.
BTW - Noble & Pico are really low-end brands.
Old 03-01-2013, 11:31 AM
1966 - 912 - SOLD
lane912's Avatar
why yes they are-
got the kit and spent sme time sourcing the conectors-
use them exstensively on my cars-
Old 03-01-2013, 11:49 AM
