vash's Avatar
i'm convinced that headlight restoration kits suck.
i follow the instructions. nothing last. my headlights are foggy and yellow AGAIN.
i am just gonna find some guy switching over to black headlights and selling the OEM's,
sanding off the UV coating and putting on headlight "Sunscreen" just doesnt work.
anything out there, you know of..that you think i should try before i put "headlights" on my Christmas wish list..hate to waste a good wish!
poof! gone
Old 08-04-2013, 09:16 AM
Misunderstood User
Vash, I used the one from Maguiars and I'm ok with it. I started with 400 grit wet paper and went to 2000 before I polished it. I did this in early May and it looks good.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 08-04-2013, 09:34 AM
Platinum Member
dad911's Avatar
I've wetsanded and used standard plastic polish with a buffer. Don't let it get too warm. Not perfect, but not bad.
Old 08-04-2013, 10:00 AM
78 in a '71
mossguy's Avatar
Griot's has a nice kit. Works especially well with a random orbit polisher.
On glide path......
1971 911 T Targa
2013 Ford Fusion Titanium AWD
Old 08-04-2013, 10:13 AM
thumbdoctor's Avatar
I've had the best results sanding up to 2000 then clear coating the opaque lens. The clear has UV protection in it.
Old 08-04-2013, 10:39 AM
Parrothead member
VINMAN's Avatar
Ive had excellent results with just simple ultrafine polishing compound and a buffing wheel. All those headlight kits are BS.
Vinny
Old 08-04-2013, 11:08 AM
you waxed the headlights after you did the restore, correct?
Chris
the more i learn, the less i know
Old 08-04-2013, 11:17 AM
redstrosekNic's Avatar
I wetsand with 600, 800, 1200, 2000, then polish, then wax. Lasts months, then just keep following up with a good polish and wax every few weeks to keep them clear. Worked on my civic, the gf's corolla, and some others.
Dustin
Old 08-04-2013, 11:19 AM
Banned
Here is a guy that seemed to have good luck refinishing his, he put a lot of work into them.
Rejuvenated Headlights
Old 08-04-2013, 11:30 AM
I wet sand mine with 500-501-502-503-504-505-506-507-508------until I get to 3007.....
Works like a charm!
Old 08-04-2013, 12:24 PM
Did you get the memo?
onewhippedpuppy's Avatar
They never look the same, no matter what you do.
‘07 Mazda RX8
Old 08-04-2013, 12:51 PM
Zeke's Avatar
When acrylic lights get yellow and dull they are too far gone to worry about making them perfectly clear and shiny.
Step 1. Take something like a diaper or soft cheesecloth and wipe quickly with lacquer thinner or acetone. Anything in that family, toluene, xylene, etc. They will be half way clear from yellow and the lens will be clear enough to function.
Step 2. Buy new aftermarket lights.
Old 08-04-2013, 02:18 PM
I just replace the headlights.
Never buy the "oem" special. Go back to the dealer and pay the $$ for the factory original stuff.
Old 08-04-2013, 02:21 PM
A930Rocket's Avatar
I gave up and bought OEM lights. Looks better and if they last 10 years again, I'm happy.
Old 08-04-2013, 03:19 PM
Edministrator
Steve Carlton's Avatar
I can hook you up with someone who does it professionally with a clear coat for $80.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 08-04-2013, 05:13 PM
mikester's Avatar
Send a message via AIM to mikester
I used the 3M kit on my prius last weekend and it looks tons better but had nothing to put on the lens afterwards to keep it clear. A layer of something needs to be applied to block the stuff that's doing whatever it is that turns the lenses yellow...
-The Mikester
I heart Boobies
Old 08-04-2013, 05:16 PM
Now in 993 land ...
aigel's Avatar
This should read:
I'm convinced that today's headlights suck
Seriously - the old days the lenses were glass - nothing is going to fade those. But then they had to get fancy and cheap at the same time and make them out of plastic. ****ty plastic.
You think the ones on new cars today are better? I sure hope so. My 2008 MS3 had the lenses peel at 3 years old, so they didn't have it down then. How about 2012 and later?
G
81 SC (sold)
Old 08-04-2013, 05:21 PM
Almost Banned Once
sc_rufctr's Avatar
Recently I did my daughters car using a buffing pad and paint cutting/polishing products.
Whenever I read about a "KIT" I get all cynical.
Turned out OK but it won't last.
As they were...
- Peter
Old 08-04-2013, 05:28 PM
Almost Banned Once
sc_rufctr's Avatar
An older thread of mine.
http://forums.pelicanparts.com/off-topic-discussions/587723-how-do-i-fix.html
- Peter
Old 08-04-2013, 05:40 PM
Retired Member
Brian 162's Avatar
I tried the 3-M kit. A lot of effort that didn't last.
One year later I had to do it again. Someone told me to use toothpaste and an old toothbrush.
It actually worked.
It was with my last vehicle. I think I sprayed a small amount of water on the lens, put the toothpaste on the lens and started brushing. Wipe away and the lens was clear.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 08-04-2013, 08:14 PM
