Recreational Mechanic
Exhaust vent hose for garage - Any inexpensive options?
Trying to find a long (11-12 foot) hose to connect to the tailpipe to vent exhaust gas out into the driveway. The way my house sits and the prevailing winds, I get exhaust fumes in the house even when the garage door is open.
All options I have found are $100-250 for heat resistant black rubber hoses. I don't need a dual-outlet setup, just a single hose. Anyone have a cheaper option, or do I have to just bite the bullet? Thanks guys!
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
I'm with Bill
You should bite the bullet here. If you have ever grabbed one of the black rubber hoses after use it is very hot, anything else might not be up to the task
Electrical problems on a pick-up will do that to a guy- 1990C4S |
Hi
I would add a blower to that hose setup as well.
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
UnRegistered User
Almost the season to look by the roadside for the exhaust hose a mechanic forgot to take off a vehicle before a test drive!
I haven't been so lucky but some of my friends have. That stuff is expensive to purchase.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Almost Banned Once
$100-250 is quite a spread. You really can't go cheap here.
Think of it this way... You'll only have to buy it once if you spend a but extra to get a decent hose. BUT, What about something from the building trade? A smallish air conditioning hose may work but I'm not sure about the heat issue.
- Peter |
Ebay flexible rubber exhaust hose < $85 (or best offer,with free shipping) You could also consider a big exhaust fan. A used furnace fan moves alot of air and should be available cheap, or even a $20 box fan in a window will vent the garage fairly quickly.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 Last edited by johnsjmc; 09-08-2013 at 12:10 PM.. |
How often to you need this? 10 to 12 ' is something you could probably do with a dryer vent, some flexible and some rigid to lay on the ground. I'm sure the official exhaust hose has to have an adapter. Perhaps they sell those separately.
Yeah, Amazon sells a couple different ones. Didn't look to see if Pelican has any. |
I use alum dryer vent hose and adapt to exhaust pipe. Cheap.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
Seems you only need a few feet of heat resistant hose. Surely by the time you are 2-4 feet from the tailpipe, heat is no greater than a dryer hose sees?
That's a great idea, I think it would work well. May not seal as well on the inlet end but close enough. I'm not looking to run the car in an enclosed area, just looking to redirect the exhaust away from my garage door so it does not blow back into the garage.
Canucks Fan
I used the same stuff when I found out the cost of the proper hose, I got about 3 feet of the straight metal dryer exhaust pipe and I'd put that on the tail pipe and the hose on the other end, never had a problem.
From the Deep Dark Jungle |
I'll be the elephant in the room. Why? Doing emission testing? I can't see any reasonable need to do this in a residential setting. Perhaps there is something not mentioned, but if you really need one of these, you shouldn't be doing it there in the first place.
Parrothead member
Ditto in the dryer hose. Thats what ive always used.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Parrothead member
Do you work on your own car??
