You sent this to me via FB lol, I live in SoCal!!
and my cars typically sit in trailers overnight.. when I know it's going to be colder than a witches tit in a brass bra
JW Apostate
I'll be sleeping in the trailer.
Sonoma race. KT
'74 914-6 2.6 SS #746 '01 Boxster |
JW Apostate
...and I don't like witches.
KT
Detached Member
Can't you just dump some denatured alcohol from HD in it?
Hugh |
How about this:
GO HOME!! You live 15min from the track!! put the car inside the trailer..
Hell Belcho
they make cheap magnetic block heaters, you know..
Saved by the buoyancy of citrus. |
When I raced Karts a guy lost a rotaxmax motor due to spitting from Iced coolant.
" Formerly we suffered from crime. Today we suffer from laws" (55-120) Tacitus |
Wind chill is a measure of how fast a warm surface is cooled. You can't cool a surface of an engine or radiator that is at ambient temperature to less than ambient no matter how much air you blow on it. Wind chill between the freezing point (0 degrees Celsius) and minus 27, the risk of frostbite is low. But a wind chill factor between minus 28 and minus 39 C will cause exposed skin to begin freezing in as little as 10 minutes. And at minus 40, you’re in a high risk situation, with exposed skin beginning to freeze in only five minutes. Machines simply are not affected.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Friend of Warren
This question comes up all of the time with boats here in Missouri. The rule we use here, that seems to be accurate is 24 degrees for 24 hours before water in the block will freeze. Last year I left a glass of water on the dock in freezing weather overnight (around 29 degrees) and it didn't have any ice in the glass. 24 degrees for a few hours is not going to freeze water in your engine. But if you are paranoid, like the others have said, drain the block.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Glen - he's not talking about wind chill. He's talking about conservation of energy and the ideal gas law. Think of how cold a carburetor gets when a lot of air moves through it. PV=nRT
. Last edited by wdfifteen; 12-04-2013 at 08:49 AM.. |
That works on the block. Not on the rad.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
That carb get cold mostly because of the evaporation of the fuel.
Yes, that's what I was saying. Not likely.
Wind chill will not lower a body to less than ambient temperature, so if Mr. Rogers was talking about wind chill, he's off base and you're right.
least common denominator
Fill the cooling system with the cheapest vodka you can find!
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
In the '20s it was common to use alcohol for anti-freeze. I was at an historic farm days event and some guy had me plowing with his 1920 Fordson, with alcohol for anti-freeze. The alcohol was boiling away and blowing right into my face. I didn't get intoxicated, but I got sick as hell.
I used the term "chill factor" to cover several types of cool down. As the previous post noted you can not get the temp below ambient but that is in error, especially if there is any moisture on the surface and you have air movement which you will, then what is called latent heat of vaporization comes into play which will act similar to what we use as a refrigeration system now days. With water that equates to about 970 BTU/LB of water. In the days before me (and I am old but not that old) ice was used and the heat absorbed by melting the ice kept food cold. I do remember my grandmother having an "ice box" until about 1952 or so!
So where does the moisture come from? Condensation mainly especially when the car is hot and then cools down at night! Sooooo, be safe and add some anti freeze if allowed. |
My grandfather talked about the old days of draining the radiator every night and having to pump water into a bucket each morning to fill the radiator so he could go to work. Ethylene glycol solutions became available in 1926. I am sure it was expensive for someone making 2.5 cents an hour. He may have used water because it was free.
Regenerated User
Three dogs under the car? Like the other guy said, "24 degrees in Napa?" What happened to heaven on earth?
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law. '72 911T 2,2S motor '76 BMW 2002 |
You spend thousands of $$$$ on a race car and you are trying to find ways to avoid putting antifreeze in it! In addition as somebody mentioned that antifreeze lubricates the insides, please just do the right thing and break down and buy some antifreeze and stick it in there. It is worth it for peace of mind....
It's in the rules that can't run antifreeze, as it slicks up the track when the hunks of junk spill it... And it's a lemons car.... Saying Trekkor has 1k in it is a stretch! |
