Sugar Scoops Rule :)
Airbag warning light - cold temps only (06 Explorer)
The yellow dash light stays on after the initial start up and stays on when the outside air temp is below 30 or so. When the outside air temp is higher, or when the vehicle is warmed up, it doesn't stay on. Any ideas what this could be?
Dave _______________________________________________ '76 911S Targa '62 VW Type 1 Sunroof '73 914 2.0 (1st Porsche, gone long ago but not forgotton) |
The Unsettler
I get occasional odd warning lights in cold weather on different cars that generally live outdoors.
Never a permanent situation and certainly weather related. Best guess, low temps affect battery possibly causing the on board computer to throw error due to low initial voltage / current draw?
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
D idn't E arn I t
Could be anything until you get the codes pulled.
With that said, I'd start snooping around the contacts between the steering wheel and column. There's a spring there that might be losing connection.
In the movies only bad guys sleep in king size beds. |
Our Toyota Highlander does that too. Usually below 20*......no idea why.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Scan check to see what is turning the light on..SIR systems perform a self test every time you turn the ignition on. With cold temps some of the components connectors terminals shrink enough to create a high resistance or open in that circuit. Electrical contact grease solves a lot of these intermittent conditions.If you can pinpoint which component of the SIR system is faulting..it can most likely be remedied with electrical contact grease inserted into the terminals. Unless the component has internal cold issues of course.
Chris 89 930 slantnose M505 k27, BB headers,kokeln I/C |
Fleabit peanut monkey
airbag light stays on sometimes - Ford Explorer & Ranger Resource "Serious Explorations"®
Apparently not uncommon. Battery.
1981 911SC Targa |
Too close the loop on this one, it was the battery. I replaced it in early Dec (before a trip to Colorado High Country and the dreaded Polar Vortex cold snap) and have had 0 repeats of the issue since.
Did you get the memo?
Weak batteries seem to cause lots of weird issues with modern cars. Glad you sorted it out.
‘07 Mazda RX8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
