-   -   Breaker panel and meter in bathroom? (http://forums.pelicanparts.com/showthread.php?t=806331)
look 171 04-16-2014 01:42 AM
Originally Posted by Jim Richards (Post 8015482)
If you haven't already, ask if their finishing of the basement was permitted. I wouldn't be surprised that it wasn't, but instead was a homeowner DiY project. But who knows. Some homeowner DiY projects are OK, others, not so much. Ask look 171 about the house my wife and I recently bought and are updating before we move into it. :eek:
A few shady spots by an inexperience DIYer, but its all gone now. Once we discovered something unacceptable, then out go the wires all the way back to the junction box unless we can repair it safely.
look 171 04-16-2014 01:47 AM
Once we discover any Mickey Mouse work by DIYers, then we tend to look extra hard throughout the house because more are to be found hidden away somewhere else. Slakjaw be careful with that and ask your inspector to have a closer look at the electrical work in areas that are normally not accessible especially above and below kitchen, baths.
71scgc 04-16-2014 07:54 AM
Be sure and get the code from your local utility on the service entry/conduit, etc.
As I stated before, many service providers have their own code which is more stringent than NEC.
Don't do any work until you find out. You may have to pull it and re-do it otherwise. Many will not accept work not done by a reputable licensed contractor.
Find out the inspection regimen in your area. You're not an electrician. Relocating a service NEEDS TO BE INSPECTED. This for your safety, and for your insurance. Sure, you can do all your own work, no law against that. You may have difficulty getting insurance, or pay a higher rate therefore.
On Code: If it was code when it was installed, it is code today. Many of the restrictions on panel placement are relatively recent, within the last 20 years or so.
Carter
slakjaw 04-16-2014 08:58 AM
Wow that was easy. there were several permits pulled on the place but none to put in a bathroom or to finish the basement. inspection is tmro so here we go.
