canna change law physics
Practical mini-solar charging station
We've been designing some mini-solar charging stations. I saw this system for sale at Costco for $99
Goal Zero Switch 8 & Nomad 7 Kit | Complete Solar Kits | Goal Zero The problem is, this thing can't fully charge an iPhone off the battery. I have a design which could charge up to 6 iPhones off the battery plus it would have a 12VDC outlet. The battery could run a LED flood lamp (75W equal) for 5 hours. Solar panels would be 15W. You could run any 12V car accessory with the unit. Is $99 a breakpoint for you? Could you afford $199 for my version? How much is weight an issue? Would 5 lbs be too much for everything? Would you pay $279 for the unit to weigh only 3 lbs? Is UL rating important to you? The Goal-Zero unit is not UL rated. How about made in USA? Our present product is $750/$999(light) 10 lbs/6lbs 144 Watt-hours - Will charge at least 25 iPhones from dead, 4 at a time. 30 Watt Solar Panel NEMA 4X/IP67 rated UL Rated Will run the LED flood light (75W equal) for 15 hours.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
It'll be legen-waitforit
I saw a unit yesterday it was a solar powered car jumper, air compressor and outlet all in one, very cool for $99
Back on topic $199 is too much, UL is important, 5 lbs is fine.
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
The Unsettler
The 4 P's.
Performance: How fast do I need to charge something? Portability: Do my activities dictate I carry it all the time or can I leave it at base. Practicality: How many devices do I realistically need to charge / run. ='s Price: How much I am willing to pay. Performance and Practicality are somewhat co-dependent. If it charges quick I don't need to charge X number of units simultaneously. For me it's not a one size fits all product.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
James
Again, our designs are presently for the industrial market, but I see people wanting these for use at hunting camps, camping, etc. For something to retail for $99, I will see what I can do. It will still be at least twice what the other guys are doing... James
James
závodník 'X'
Ps: Skip the UL marketing and wasted dollars for acronyms.
“When these fine people came to me with an offer to make four movies for them, I immediately said ‘yes’ for one reason and one reason only… Netflix rhymes with ‘wet chicks,'” Sandler said in a prepared statement. “Let the streaming begin!” - Adam Sandler |
Can I sell it in the UK for you?
BTW sounds like it could be a great product.
88 carrera Using the teutonic shift method since 1990. |
závodník 'X'
mini? go big time
I think you need sunshine for the solar part.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
$99.- for "'Goal Zero" 8 Watt solar panel? Why not get HF 45 Watts for $199.-?
Solar Panel Kit - Save on this 45 Watt Solar Panel Kit
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
The Harbor Freight kit doesn't include a battery
And UL isn't marketing. It is safety.
Banned
lite and anti-corrosive for boat use ?
lots of boats are keep at anchor not on a dock with shorepower |
The Solar Panels are 6061, so they are marine grade. The systems are NEMA 4X, waterproof and non-rusting. So, yep they will work in a Marine environment,
I would say you need a couple different models, does your devise have a 110 outlet
To run a power tool? Or is it set up to drain and recharge slowly. |
I think compactness, durability, quality of materials, and ease of use are more important that sheer weight. You sacrifice all of the above for less weight. Look at hiking gear.
I would buy a charging station that came either in a case or was durability coated, has an attached cord so that you can't lose all of the little pieces, and was well made. I'd spend up to a few hundred bucks if it could recharge my laptop and phone. I don't need to run power tools off of it. I have generators for that kind of thing. |
I do make larger systems which incorporate inverters, but we're talking about a tiny system for around $199.
závodník 'X'
It is a big part of product marketing and a lot of bs too. I happen to be near the labs and without getting my azz dragged into some legal fiasco, have heard of some troubling tactics. Money grab by an independent company. BTW: Have had not one BUT TWO U.L. approved Bunn coffee makers gone bad and of a dangerous design. In fact, one was recalled and the replacement had the same problem.
Old article but nothings changed. UL Drawing Fire on Product-Safety Tests - Los Angeles Times Just build a quality product and c.y.a..
