I wouldn't see it as a big deal and I'd do the splice over with SC 80 conduit bit as well. Way not worth all the trouble of possibly pulling the old conduit up and back into the can. The local power company probably will not fix this on your property. They may, however, disconnect the line so that you could pull the conduit up where it belongs if you don't want to go the route of splicing over it.
BTW, the home inspector missed the not being allowed to have phone interface attached to conduit... I'd remind him of that. NEC 300.11 (B) |
That's more then a couple of hundred bucks around here for a fix like that if you hire a lic. electrician. A handymandelux will do it for a hundred or even less. hell they wouldn't even have to talk to you because they can't speak to you.
And NO to the response of codes being "guidelines".... Adopted code is law, law broken get citations.
2 reasons this may be a required fix.... 1 if the conduit was used as a means of grounding/bonding the equipment. 2 if not having that conductor covered was seen as "subject to physical damage". I see the second as the only possible in this case. Therefore, covering with Sch 80 conduit would be fine. |
Either direction is fairly simple... If you really want this buyer and it's that close to a deal either call an electrician to pull the conduit up or if you're feeling "thrifty" contact the electrical utility and ask for a disconnect so you can pull it up yourself.
My guess is the conduit probably goes down 3' or so and may have a "slack box" at the end. Pull meter, dig out conduit,pull up, re-attach fitting, re-tighten clamps holding conduit to house, Juice it .... Wouldn't take more than a couple of hours so even ice cream won't melt in the fridge |
I'll probably just call someone and at least have them give me a quote. If it's <$500, I'll probably just let them do it. If it's more, I may start digging.
The Unsettler
When I sold my last place there were a couple of code issues that needed to be addressed.
We wrote it into the contract that we would address them and left cash in escrow to guarantee performance. It's an option if time is a factor for closing as it was for us.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Unfortunately it looks like they tore out the oversized knock out in the panel so the feed will need to be disconnected to repair properly. Other than that, just dig down to the sweep and then back 5-10' and that should be able to be jacked into place. Can't blame the buyer for wanting that fixed, I would have never even put it on the market until that was done.
Get a quote and have the buyer fix it and refund them the money at the close of escrow. This way, you are not under the gun for the fix and they know you mean well. You agent should negotiate that easily if they really want the house. Show the estimate to them.
I've got an electrician coming by tomorrow to look at it.
I should have written it clearer. Refund the money to fix the issue at the close of escrow to the buyer so they can fix it themselves after closing.
no, I understood. I had proposed that to my wife when we got the list of things to fix on the house. I'd been working on the house every weekend for a while before we put it on the market to get it ready to sell. I'm ready to not work on anything any more, but I'm sure the allowance that we would have to give them to fix things would be much more than it would cost for me to fix several of the little things. I'll be getting pros to do a couple of things. I've already done several myself.
Oh yeah fix the easy stuff and have someone do the PITA things you absolutely hate, if not, make a deal. Are you moving to a bigger house? you are willing to leave all the custom wood work bahind and start all over again?
A specific washer usually fixes that problem. I have never had to replace a big one like that. If they are torn really bad, I usually just convince the owner to just replace it and deal with the liability of fixing a clapped out panel. Its just not with it to me.
Out of curiosity I asked a technician with our local electrical utility. He said our electric company would come out and put in a new meter base. The line is their responsibility up to the meter and they don't want the liability of any f-ups.
Thanks all for all of the advice. The electrician came out this morning and looked at it. He said that the best route would be to move the meter down on the wall so it meets the conduit and then change the conduit between the meter and breaker box to a dog leg. He also said that the meter box looks original and so they would probably replace that because it's not unusual for the places where the power connects to bend due to the house being lifted. He also said that it would entail almost an entire day with no power in the house...
in Houston... in August. Oh, hell no. I thought we could schedule the work after we move out, but before the closing. Previously, I had considered offering an allowance to the buyers so they can get it done, but I've been able to fix 6 or 7 of the things that they wanted fixed and only have 2 or 3 things left. I think we are going to offer them an allowance so they can get the rest done themselves. Honestly, I doubt they'll get any of the stuff fixed because it's all pretty minor. I would assume the biggest possibility for issues from this particular item is that lizards or something could crawl up inside the meter. I've seen them inside the breaker box over the years, so they could probably already get into the meter.
The utility co doesn't give a rats ass about your need to do this quickly and hopefully not too expensively. I would just call an electrician. But is that direct burial cable?
Rusty Heap's suggesting is looking pretty good right about now.....heh.
Old dog....new tricks..... |
I forgot to say, the guy said the cost would only be 450-550 or so. Which to me, doesn't sound that bad. The worst part about getting the work done is having 12-24 hours of no power (and therefore, no AC which is unthinkable this time of year) I suspect the buyers will jump at us giving them a little money so they can get it fixed. They are very eager to move in before the 25th. Honestly, I'd be surprised if we could manage that anyway, but I'd like to get moved soon too.
