-   -   Wireless TV? (http://forums.pelicanparts.com/showthread.php?t=826546)
A930Rocket 08-22-2014 09:52 AM
Wireless TV?
Is there a set where the TV can be wireless with a transmitter in another spot of the room?
We can get power. Just need to get the cable to a wireless system.
We need a set up like that for my son's room at school.
stomachmonkey 08-22-2014 10:12 AM
You can pick up aftermarket streaming devices but they are a) not cheap and b) a bit spotty.
Look at the Silicon Dust offering, HDHomeRun DUAL - Generation 4 - US - Watch Streaming TV Anywhere
You'll still need a PC at the TV, unless it's a Smart TV that supports DLNA streaming.
A PlayStation 3 will work.
You could also go Raspberry PI, cheap and comes with OpenElec as a an OS option but the PI is painfully slow on channel switching, menu navigation etc....
jyl 08-22-2014 10:20 AM
30 feet of coax and some floor tape? Using wireless to span a dorm room seems a bit much.
stomachmonkey 08-22-2014 10:28 AM
This.
Run it along the baseboard.
50 footer at Loews, $15.00
5 minutes of work.
A930Rocket 08-22-2014 10:35 AM
True, but it would cross two door ways and we were trying to avoid that. I didn't know if there was a cheap wireless out there.
Since it's a dorm room, I might try those stick holders with zip tie and just go around the ceiling.
<!-- BEGIN TEMPLATE: bbcode_quote -->
<div class="pre-quote">
Quote de <strong>jyl</strong>
</div>
<div class="post-quote">
<div style="font-style:italic">30 feet of coax and some floor tape? Using wireless to span a dorm room seems a bit much.</div>
</div>
<!-- END TEMPLATE: bbcode_quote -->This.<br>
<br>
Run it along the baseboard.<br>
<br>
50 footer at Loews, $15.00<br>
<br>
5 minutes of work.
Porsche-O-Phile 08-22-2014 10:40 AM
Can you just plug in an Apple TV box and connect to a wifi connection? That's all I do. Only cords involved are the power for the screen, power for the box and HDMI from box to screen (can be virtually any length you want - 3' or 50' away).
LeeH 08-22-2014 10:45 AM
Haven't used this, but other Rocketfish stuff I have has been great:
Rocketfish™ - Whole Home HD Extender - Black
Transmits through power lines, so may be an issue in a dorm.
TimT 08-22-2014 02:25 PM
I have a Brite-view HDelight gizmo that I have to beam my STB to a tvin my kitchen..
Yea this was a more expensive way to get the tv into the kitchen. However my house is 110 years, old stucco exterior, plaster interior. I don't like cutting unnecessary holes in the plaster if I can avoid it, and pulling cable though the walls is a pain. So I got the brite view unit.
The receiver is about 25 feet from the transmitter, It very rarely drops the signal..
So far it has worked well for my for a few years..
vash 08-22-2014 05:05 PM
wireless TV has the creepiest commercials. hahaha...
smg911 08-22-2014 09:30 PM
$200.00 at Best Buy. Provides a wireless connection between the cable box and the TV.
