Rick Lee's Avatar
Any plumbers in the house?
I replaced my kitchen sink faucet today and it was quite a job. I broke the flexible copper hot water line that goes from the wall under the sink to the faucet. No biggie. I sort of wanted to upgrade to those 1/4 turn valves anyway, so I did. I used telfon tape and tightened it all very snug. Both hot and cold valves from the wall leak now. They're not cross-threaded. There's teflon tape on both and now I've even packed it all with plumber's putty. No good. What to do here? I really need water in the house and both drip a little. How to fix? Tighten until I feel like it's gonna break? Use some kind of sealant or silicone?
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 10-12-2014, 06:15 PM
Hads930's Avatar
Rick not a plumber but my brother is a licensed master. Done enough to know that putty traditionally is used to set faucets and drains. Did you use putty or "pipe dope", which is a common term for threaded pipe lube/sealant. On old pipe I usually use both tape and dope. I think there's a plumber on here with the official fix, just thought I could get you headed towards a fix.
Old 10-12-2014, 06:25 PM
Bill Douglas's Avatar
I do thirteen turns on the tape.
Old 10-12-2014, 06:31 PM
Old 10-12-2014, 06:33 PM
Rick - this is what I use.....
Old 10-12-2014, 06:35 PM
Lol
Old 10-12-2014, 06:42 PM
Information Junky
island911's Avatar
Are you sure that you have the right type of fitting on the valve? ...mating to the line.
Some use a compression fitting, some don't. (I am not a plumber. I don't even have the right pants to show butt-crack)
Old 10-12-2014, 06:44 PM
Do you have a male thread coming out the wall, is it copper? Tha other style is compression, it has a small copper ferrule? If it is compression you need to change the ferrules . There is a puller..or you can use a hack saw blade fine tooth, careful not to nick copper tube.....can you post a photo?
Old 10-12-2014, 08:36 PM
Rick Lee's Avatar
I'm so exhausted, I don't care if the house floods - I'm not touching this again for a few days. The lines coming from the wall have no threads - just the nut and compression ferrule. I had to Dremel the old ferrules off, but didn't nick the pipes. Then I retaped everything, installed all new hardware and it seemed to be fine. We just came back from dinner and there's a very tiny drip, like a small drop every 45-60 sec. I'll snug it down some more, but not tonight. What a miserable job this was.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 10-12-2014, 09:08 PM
You do not have permissi
john70t's Avatar
I used to use that stuff on tractor/trailer air lines.
Much high pressures than water mains.
Let set an hour, good to go.
If it's after the 1/4 turn valve, you might as well glue it.
Those only last 5-10 years anyways before they freeze up to corrosion.
Old 10-12-2014, 09:23 PM
Rick, you have a compression fitting. You gotta crank it down a bit to stop the leak, so give it a go. Is that the only place that's leaking, the compression nut and the pipe? Do not over tighten the supply lines or they will leak over time. Hand snug as much as you can and give it another 1/4to 1/2 turn and leave it be and come back and check in a couple of days. Over tightening destroys the rubber seal.
Old 10-12-2014, 10:04 PM
Cajundaddy's Avatar
Compression fittings are often the ones to bite you. The tubing needs to be de-burred and completely clean and round. Sometimes it will get dinged or flat-spotted and won't seal. Once you are sure the tubing is clean, Use a fresh ferrule, bottom the tubing into your threaded fitting, lube the threads with a little silicone lube, and then hand-tight plus 1.5-2 turns. No teflon tape or sealant is needed if the tubing is clean and round because the ferrule makes the seal..
2021 Cayman GTS 4.0L
2020 Macan (dog hauler)
Old 10-12-2014, 10:05 PM
Oh, no need for any pipe dope or teflon tape. As they say, do it dry.
Rick Lee's Avatar
I put a bowl under it and an hour later there was less than 1/4 tsp. of water in it. So I'll ride this out for a few days before I get down there again. I'm so beat. I got a new amp this morning and haven't even been able to play but about an hour today.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 10-12-2014, 10:11 PM
UnRegistered User
billybek's Avatar
Did you put new ferrules on exactly where the old ferrules were located?
When under compression, the ferrules will make the OD of the pipe slightly smaller. Putting a new one on exactly where the old one was probably wont seal no matter how tight you make it.
Cut back the copper to remove the ferrule and slide another on.
I don't use tape or pipe dope on compression fittings.
Bill K.
Old 10-13-2014, 06:26 AM
Cymru am Byth
carmad's Avatar
I have used these in the past, work great, when I could not get compression fitting to stop leaking.
Plumbing Supplies: Plumbing Fittings, PEX Fittings, Parts & Products Online
1986 930 (Gone but not forgotten)
1995 993 (Should Never Have Sold it)
2007 BMW 328Xi Sport Wagon
2005 Lexus GX470 Offroader
Julian Williams
Old 10-13-2014, 02:36 PM
peppy's Avatar
+1 on the shark bites. I don't use compression fittings any more.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 10-13-2014, 02:49 PM
JavaBrewer's Avatar
We're talking compression fittings right? Wow I never had a problem.
- remove old section of pipe where old fitting lived
- sand paper the copper pipe to clean it up
- install compression fitting and water lines and lightly tighten
- turn on water
- tighten fitting using two wrenches (one on nut and other on fitting) till the water stops leaking
I admit getting the right access to do those steps can be a challenge. I loathe working on plumbing but generally have success if I follow the steps correctly.
Old 10-13-2014, 02:53 PM
plumb4u2's Avatar
as stated you can NOT cut the ferrule off and put new one in its place
the copper needs to be cut and new ferrule installed
Justin
84 Carrera Targa
98 F-150 4x4
Old 10-13-2014, 02:54 PM
Information Junky
island911's Avatar
+2 They are pricey, but make quick work of any job.
Old 10-13-2014, 07:19 PM
