I've been here before......Its not very difficult to modify certain circular saws to a zero clearance on one side. Once done its a lot more difficult to return the saw to its original configuration. I made mine from a yard sale $5.00 saw. Wish I still had it, I would take some picks of it for you.
I've driven alot of crap to get here man! |
How about your angle grinder ... use a thin cut off blade, set your guard to the req'd depth and cut away.
Old dog....new tricks..... |
cant you just score it and snap it off?
i have one of those vibratory saws that would get thru that..but you hands would be numb
poof! gone |
Did you get the memo?
Sawzall. If you just get close to the corners you can pry the sheet off, then finish off the remaining corner pieces with a hammer and chisel. If you don't have a Sawzall, it will be worth every penny. The name says it all......
‘07 Mazda RX8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Let me know when you start to do that. I will just drive to another county for the day just to avoid getting hit by your grinder when it pinches and fly off your hand. That's nuts. I know there are many tools out there, some are not so safe and that's one of them.
The trick with a plunge cut on the Sawzall (ahh, that's how its actually spelled? I have never noticed) is to make sure the foot is always in contact with something. Jam the foot onto the OSB and plunge the blade into the material or lift the saw from the back end. Once you get a little spot going, the rest goes pretty easy.
Cut-off tool. You can get them air powered or electrical. Put a wood blade on it and remove the shield (wear glasses when using).
Bunch of old cars
If not a good sharp chisel and hammer, what about this Dremel with depth guide?
Data Farmer
As usual, The blade I want has been patented, but not produced. It has a very long convex cutting edge,
I did find this and ordered it (cheap) so we'll see. I like that lancelot thingee. Does it jump/kickback like a chainsaw?
Yep...looks a lot safer than most of the suggestions and is designed to make a flush cut (when you put on that blade). There is a video clip of one posted near the top.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
In the past i have made a blade like that. its not hard to cut teeth with angle grinder. might take a few times to sharpen it up to do all that but itll work. a vibrating miltitool with a good blade should work good too. we have a Fein Multimaster. harbor freight has a cool grinder wheel that has a chainsaw blade around it. id say that should work too. or just use a chainsaw
82 SC , 72 914 |
Kantry Member
Best Les
Best Les My train of thought has been replaced by a bumper car. |
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Cut???
The plywood appears to be nailed in place. If that is the case, you'll eventually end up with a nail pulling devise....like a claw hammer/crow bar. There are special tools that will pull the nails.....powered by your basic hammer.
JPIII Early Boxster |
Banned
Data Farmer
The sad thing is (being a tool addict) that I will most likely end up buying ALL of these tools just to have them, even if the $4 sawzall blade is all I need.
Thanks guys. Ron |
Model Citizen
They keep it safe by limiting it to 14000 RPM.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
https://www.sunbeltrentals.com/equipment/detail/995/0040070/toe-kick-saw/
Toe Kick saw rental - in my zip - $15 for 4 hrs, $21 for a day. And be done with it!
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
