Are you sure it's not because it out gasses too much, Hugh?
Scott '78 SC mit Sportomatic - Sold |
Bill is Dead.
Are you sure it's not because we are afraid of alien civilizations procuring our Loctite technology, Hugh?
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
Detached Member
Pretty sure its the deformation of the light weight bolts that they use. Titanium I believe. I have a "used" bolt (pretty big, like 2" long and 1/2" diameter with a weird looking head for torquing, that is serial numbered and made of Ti, it has some blue locktite blob on the side of it. I know once put on and tightened, if loosened, they throw it in the scrap pile.
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Platinum Member
Rust. After spending three hours this afternoon grinding the heads off of bolts to an access panel, I've decided rust is the best locking mechanism for nuts and bolts.
You do not have permissi
dad911:
$30 angle grinder from harborfright will get er done. First try hammering on face, impact and lube back and forth, heat, and torquing until the bolts snap in two. Last edited by john70t; 12-15-2014 at 06:30 PM.. |
Unregistered
The bolt for bike rack is >1/2", too big to tighten until stretch.
The joint looks like a hack, not something you'd find on the space shuttle. In this case the bolt is tightened, it holds the far side of the rack against the hitch. Holes are oversize so loose fit, probably there is motion too. Ok, so what is a general rule as to when a split lock washer is reasonable? I can guess: "might be reasonable for a loose hack fest" but hoping for something more formal. I don't even know how to characterize this situation. |
