LakeCleElum's Avatar
Make sure you know your radio and Nav codes before disconnecting the battery....
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 03-06-2015, 10:57 AM
David's Avatar
These little issues aside, I still want a Cayenne Turbo.
Old 03-06-2015, 11:00 AM
Did you get the memo?
onewhippedpuppy's Avatar
The newer Porsches all have a fiber optic network, the codes are internal to the units and modules. Only a pain if you have to replace a radio, then you have to have your dealership code the radio to the module.
Really the battery placement is nothing crazy. How many cars have their batteries out in the open? I've had multiple cars with trunk mounted batteries, under seat mounted batteries, batteries hidden under crap under the hood, etc. Easy maintenance is a thing of the past.
Old 03-06-2015, 11:03 AM
gtc gtc is online now
abides.
gtc's Avatar
Originally Posted by David View Post
What a weird place to put the battery!
I guess it keeps the center of gravity low.
You think the battery placement is weird? How about putting the starter under the intake manifold and below the plastic coolant pipes.
Graham
1984 Carrera Targa
Old 03-06-2015, 11:24 AM
Every car I've ever owned...except for the Audi (it's in the trunk, and easy to remove).
Guy
'87 944 (first porsche/project car)
Old 03-06-2015, 11:29 AM
Now in 993 land ...
aigel's Avatar
Originally Posted by Porchdog View Post
The price of lead is sky high. All batteries are expensive right now.
Holy moly. I checked and prices doubled since the last time I bought a battery in 2013. I put an oddysey into the 993 a year or so ago but that was probably not dominated by the price of Pb.
G
81 SC (sold)
Old 03-06-2015, 11:38 AM
No kidding. I'm still perplexed how the hell you get the battery out of my new escape.
It's under the black box next to the firewall behind the brake booster! I guess you disassemble the intake?
Old 03-06-2015, 11:46 AM
mikesride's Avatar
So....your battery is dead, and the first step is to move the electric seat controls in order to access same said battery??? Is there a manual override to move the seat?
I've driven alot of crap to get here man!
Old 03-06-2015, 01:18 PM
Scott R's Avatar
We've gone through a battery every two years on our Cayenne. Porsche told me it's because the car largely sits unused. But when it's starting to go weird things start happening with the security module, and the dashboard display. It starts with the security module setting itself to "honk" when armed when I normally have it turned off.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-06-2015, 02:36 PM
Send a message via AIM to fintstone
On mine the seat just unbolts in the front and folds back...
Old 03-06-2015, 02:37 PM
Information Junky
island911's Avatar
There are jumper lugs under the hood ... which opens mechanically (for now
Old 03-06-2015, 06:32 PM
chocolatelab's Avatar
Got it back,
Feels much better at start up.
Starter working fine.
H9 size battery should you ever need one.
1978 911sc Targa Sold 2001 996 Cab Sold
2006 Cayenne S Silver Wifes Car for sale
2011 Jeep Wrangler Silver for sale
2010 Toyota Prius Black for sale
2016 BMW 328D wagon
Old 03-06-2015, 10:30 PM
Originally Posted by aigel View Post
Why is the battery at Autozone $200? Last time I bought a battery, the top of the line stuff is maybe $90?
I start seeing Cayenne Turbos for $20k and less. Intriguing ...
G
I said about $200...just a WAG. The Cayenne uses a lot of juice and I would want a pretty good battery if it is going to be under my seat. Also needs to be vented...an of course...it must fit. The one I used is actually 142.99 plus tax. Duralast Gold H8-DLG
900 Cold cranking Amps (1000 cranking Amps) ***. 150 Reserve minutes. Warranty consists of 3 years free replacement plus 2 years prorated.
This is only the second battery since new in my 2004...but it is a daily driver.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 03-06-2015, 10:57 PM
I've had two Boxsters with dead batteries recently. Unfortunately in their infinite wisdom, all of the newer Porsche cars starting with the later 986/996 models have an electronic trunk release. So when your battery is dead, you can't pop the trunk to replace it. Brilliant! Fortunately they have a jumper in the fuse box in the driver's side footwell, but I've had a battery so dead that it wouldn't take a charge. In which case you have to pull the driver's side wheel, pull the fender liner, and find the emergency trunk release cable.
I guess that's what we call progress?
‘07 Mazda RX8
Old 03-07-2015, 04:28 AM
Lesson learned, don't let the 986/996 get low on battery!
Old 03-07-2015, 07:23 AM
