Cleaning the MAF, how to?
My Miata has a chronic rough idle, have done the full tune up (Plugs, cables, filters, checked timing, etc.).
It has been suggested I clean the MAF, can I just pull it apart and spray it with carb cleaner? TIA |
Use MAF cleaner, it is less harsh. If it's too far gone no cleaning will bring it back.
CRC Mass Air Flow Sensor cleaner has worked well for me.
I cleaned it gently with the crc stuff and it didnt really help. Since my next step was to buy a new sensor, I got a bit more midevil with the stuff and sprayed tons of it directly into the sensor. I used basically the whole can on the sensor. Car ran like a champ right away. I had gotten so use to the stumble at 4 k-rpm that it surprised me occasionally when it was gone |
Thanks guys! The CRC MAF cleaner is about $10 a can +\-, removing and cleaning the MAF will be more of a problem than cleaning. I will also inspect all the rubber manifold fittings/hoses for cracks seeing as that can be the cause of a rough idle.
What do the "experts" on the Miata forums say? With my Chevy HHR questions, I check the HHR forums and they are generally spot on. Their advice was about you said you are going to do so I guess it is pretty much the same for most makes?
make sure you don't touch the wire.... I usually just spray it with it in place
If you do need a new one, it never hurts to take a flier on a junkyard MAF, IMO. Not with how much cheaper they are. |
| All times are GMT -8. The time now is 10:10 PM. |
