least common denominator
Cleaning the MAF, how to?
My Miata has a chronic rough idle, have done the full tune up (Plugs, cables, filters, checked timing, etc.).
It has been suggested I clean the MAF, can I just pull it apart and spray it with carb cleaner? TIA
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
Did you get the memo?
Use MAF cleaner, it is less harsh. If it's too far gone no cleaning will bring it back.
CRC Mass Air Flow Sensor cleaner has worked well for me.
Mike |
my subaru had a studder at 4k rpm for literally 3 years or so, finally it threw a maf related code.
I cleaned it gently with the crc stuff and it didnt really help. Since my next step was to buy a new sensor, I got a bit more midevil with the stuff and sprayed tons of it directly into the sensor. I used basically the whole can on the sensor. Car ran like a champ right away. I had gotten so use to the stumble at 4 k-rpm that it surprised me occasionally when it was gone
84 930 18 Cayman GTS |
Thanks guys! The CRC MAF cleaner is about $10 a can +\-, removing and cleaning the MAF will be more of a problem than cleaning. I will also inspect all the rubber manifold fittings/hoses for cracks seeing as that can be the cause of a rough idle.
What do the "experts" on the Miata forums say? With my Chevy HHR questions, I check the HHR forums and they are generally spot on. Their advice was about you said you are going to do so I guess it is pretty much the same for most makes?
make sure you don't touch the wire.... I usually just spray it with it in place
76' 911s Signature Edition |
If you do need a new one, it never hurts to take a flier on a junkyard MAF, IMO. Not with how much cheaper they are.
-Brad 2002 Carrera2 1986 944 Turbo |
