Bill is Dead.
I can't help myself....
Give 'em the clamps, Clamps!
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
Platinum Member
Many of the Electrical threads I read about here are determining excess battery draw, or 'is it my battery or alternator' or "why is my wire hot/smoking"
That's why I highly recommend a clamp-on DC (many mutimeters are AC only) meter. Just clamp it around the wire, and measure current. Many meters & fuses smoked with people trying to measure current. For temps a decent IR Temp gun ($20ish on amazon) is far more useful than a multimeter with a probe. Also, As I posted earlier, the 12v test light is often more useful than a meter. It will determine not only if there is voltage present, also if it is at a reasonable enough current to light the bulb. For example, a circuit with alot of resistance(corrosion) may still measure 12v on a high impedance meter, but drop to zero under load. |
Recreational Mechanic
Ok guys after obsessing over this for awhile I bought Klein Tools MM2000 TrueRMS meter. For the price point $120 and features it seemed to be the best choice for me. This meter is comparable to the Fluke 117 but considerably less costly and has more features. A clamp meter would be nice if I was doing mostly AC but it appears clamps are tough to use in tight automotive spaces. Thanks to all who responded with suggestions.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
1986 Bosch Icon Wipers coupe. |
Platinum Member
Yup. As a check put a 1k ohm resister in series with the positive voltmeter lead on your 12v battery and you will still read 12v.
