High tech repairs
Or "McGyvering" if you will. The problem, passenger door on my Hot Rod would fly open over bumps or in strong winds or whenever it took a notion. So off to the hardware store for a sliding bolt latch, which mostly cured it. With the clothespin
wedge it fixed for good. And my driver side window wouldn't stay "UP'. so found a fix for that too. All this because we're preparing to head off to Maine next week, and there are lots of bumpy roads down there. So at least now my wife's door wont fly open, she's less likely to be ejected. I hate it when that happens!! ![]()
A latch and sheet metal screws will also work. Note the small hole in the lower portion of the door and hardware store latch.
Model Citizen
(You should rig up a lanyard for the clothes pin so you don't lose it somewhere in Rhode Island!) (Edit - you said "Down there" - you must be a Canuck, disregard Rhode Island and insert your own geographical reference)
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" Last edited by herr_oberst; 09-08-2016 at 07:30 AM.. |
Reminds me of a room mate's Model A he'd cobbled together from pieces & parts. Got the radiator out of a field & scavenged other parts from different places. One of his most interesting mods was the headlight switch. It was one of those half/half household light switch panels that had a switch to flip on the top & a plug in receptical under that covered by a regular, ivory colored plastic cover. There was an electrical wire that came out from under the car's instrument panel & plugged into the outlet. To turn on the headlights, he flipped the light switch. To change from low beam to high beam, he pulled the plug out, flipped over 180 degrees and plugged it back in. It was pretty cool.
Marv Evans '69 911E |
PS: Did you notice my "trouble free" check Engine light? Last edited by yellowperil; 09-08-2016 at 08:47 AM.. |
Model Citizen
Another solution from the Red Green show:
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
coulda, woulda, shoulda
careful now, you're getting into rat rod territory. new original style latches are only $25... changed them out on my 29 and they work fine. the hard part was getting 86 yr old rusted seized screws with stripped heads out
John 74 911s They laugh at me because I am different. I laugh at them because they are all the same. |
I was thinking of installing the suicide door safety bolts but, man it's a big job and I find it easier the easy way. This will have to do for now. |
my friend has these on his 35. damn safe but in the way for me to install windows. I'll have to modify them to open from the outside also.
Just watched the Red Green power window winder. Great idea, makes my elastic band solution look not so smart.
He is a god up here in Canuckland! |
