Don Ro's Avatar
Disc Brake Caliper Piston - Lube or Not?
On a BMW motorcycle.
Cleaning the calipers and replacing the pads...should I lube the pistons (pucks) or not?
If so, what to use.
Thanks.
Don
"Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence."
- - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View
Old 12-11-2016, 09:20 AM
Don Ro's Avatar
Been reading online and some say that silicone will swell the seals...others say no. What say?
Don
Old 12-11-2016, 09:40 AM
The answer is from your inspection. Are the calipers working fine, and no cracks in the rubber dust seals? If they would keep working fine with just a cleaning and brushing off of the brake pad dust, then why take them apart?
Old 12-11-2016, 10:29 AM
Don Ro's Avatar
Not taking them apart...but two of the four pucks don't move as quickly and smoothly as the other two. They're clean but just a little sluggish when I pump the lever...so thought I ought to lube them a bit. No?
Don
Old 12-11-2016, 10:48 AM
Max Sluiter
Flieger's Avatar
No lube. The brakes work by deflecting the seals. The only time they actually slide is when the pads have worn enough that they need to self-adjust.
I wouldn't want to mix anything into my brake fluid. Silicone fluid is know to be very spongy since it dissolves air much more than normal DOT4.
Ultimately, I'd consult the repair manual.
Old 12-11-2016, 11:49 AM
Super Moderator
cstreit's Avatar
We used to recommend PBR rubber grease. Non deforming. You can only buy it in huge tubs now though... So Alcon makes these small containers specifically for brake seals and pistons: https://alconkits.com/tools-and-supplies/tools/alcon-caliper-grease-replaces-pbr-rubber-grease-detail
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-11-2016, 12:05 PM
