Air Medal or two
afterburn 549's Avatar
Friction Loss Question
For example, let's use 10% as the arbitrary power loss somewhere between the engine transmission on a 100 HP vehicle.
That should read about 90 Hp on the dyno, subtracting the 10 hp figure correct?
Now, lets add a few parts to make it a 200 hp -
The deduction baffles me because now there is a subtraction of 10% which means there is a loss of 20 HP.
However, this is how its done in the industry and i think it might be wrong
Why would there be another 10 hp loss?
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 12-17-2016, 01:51 PM
Eric Coffey's Avatar
AFAIK, the frictional losses from the drivetrain are proportional to the power (load) being transmitted through them. There are also "fixed" losses that remain constant, no matter what the power/torque levels are. That said, there is no way a standard percentage value can be used for an accurate calculation, especially across different vehicles/engines/drivetrains. I think it's more of a rough guideline at best, and I've heard anywhere from 10-20% used as the "percentage of loss".
Old 12-17-2016, 02:40 PM
Air Medal or two
Like I said, just because the engine jumped a 100 HP why the extra loss?
One could say "the New CR did it", but a turbo would not necessarily have to be bumped a couple points.
Confused.
Old 12-17-2016, 02:48 PM
Bland
unclebilly's Avatar
Why do high performance cars need a tranny cooler whereas commuter cars do not? Assuming both have the same parasitic losses in the trans...
Old 12-17-2016, 09:02 PM
White and Nerdy
Tervuren's Avatar
As force is increased, so is friction.
Think of sliding a 200lb object across ice, now try sliding a 400lb object across the ice. Even if you have the object on a low friction surface, the 400lb object will have more drag on the ground.
You increase power, either by increasing speed(RPM), or Torque. The faster the transmission moves, the faster the frictional parts come apart and together, increasing friction.
There are reasons several forms of US racing use systems that do not change gears, more power to the wheels this way with less moving parts.
Shadilay.
Old 12-17-2016, 09:15 PM
Information Junky
island911's Avatar
also consider(typical gear box) that involute gear faces roll (not slide) from one face/tooth to the next. But, as loads (and especially over-loads) are applied the gear, teeth deflect causing the profile to no longer be that great mathematically perfect involute rolling/meshing interface. IOW, the gear teeth start to slide past each other at the contact(mesh)
All this means that gear friction is a function of torque. And also, that the doubling of the load could make for more than doubling of the friction.
Old 12-17-2016, 09:36 PM
Air Medal or two
Nah...I see what you are saying...but,...nah
Jump from 100 HP to 200 HP .
There will be no added 10 hp added loss.
SEE?
That's what I am saying....these arbitrary numbers floating around....
Just changing HP can not cause more drag.
Old 12-17-2016, 09:43 PM
There will. Just using your example... doubling the horsepower of an engine. More power can be achieved with higher rpm. Same parts now moving greater distances in the same amount of time, equals more friction. In order to make those parts live at the higher rpm means for one, greater valve spring pressures, this puts more stress on rocker arms, pushrods, lifters, cam lobes, etc. more pressure equals more friction. Now you have Pistons rocking in their bores at a higher rate yep, more friction. Now the crank is moving around in its journals more creating more friction.
Or another way to take your engine and make it double its Hp. Make it larger. Now the larger pistons, possibly traveling further in their bores, actuating larger valves, etc. More surface area, more friction.
Forced induction? More pressure on the same components, more friction. The internal combustion engine is very inefficient because it looses so much to friction. The heat generated in an engine isn't from combustion alone. It's friction. Work it harder i.e. more hp, that means more heat, from more friction.
Old 12-17-2016, 11:20 PM
wdfifteen's Avatar
Losses might be 10% or they may be more or less. The SAE has concluded that every drivetrain is different and assuming arbitrary % loss is not accurate.
In real life drivers have to let their 500 hp engines loaf along (for traffic or whatever) most of the time. Drivetrain loss is a function of the power the engine is actually producing at any given time, not it's potential. Doubling the HP capacity of the engine won't materially affect transmission losses if you maintain the same driving style. Is that what you mean?
Yes it can. More power creates more friction which creates more heat = more wasted power. Faster rotational speeds increase windage losses. This assumes you are actually using the horsepower.
"In any drivetrain component with meshing gearsets, heat generated by contact friction between the gears is a significant contributor to drivetrain loss. This is true during steady-state driving, but is far more of an issue when the throttle is mashed to the floor and the resulting thrust force and angular acceleration builds up in these drivetrain components. The heat generated by this dynamic friction is absorbed by the transmission and differential fluid as well as radiated to the atmosphere through the transmission and differential housing(s), and in some cases, via a heat exchanger or oil cooler. This absorbed and radiated heat is literally the conversion of engine torque into thermal energy because you can't technically "lose" power, but can only convert it into other things (some of our favorites being forward motion and tire smoke)."
Drivetrain Power Loss - The 15% "Rule"- Modified Magazine
Old 12-18-2016, 04:50 AM
Air Medal or two
You guys I think are missing the point or, I have some density .
( which is possible )
Either way let's try this example as it is real EZ to repeat what we have been told for a forever about drive train loss.
Lets take the 100 Hp engine , add a turbo and dial in 200 HP.
The HP / TQ will rise to 200 but the RPM will be the same in this scenario .
The only added drag will be the exhaust pushing the spool, is that going to eat 10 HP?
If it is , it is not going to consume the 10 HP under all conditions .
So it would not be a strict rule ( the loss)
Just thinking here chewing the cudd .
Old 12-18-2016, 10:51 AM
beepbeep's Avatar
I beleive OP is talking about drivetrain loss, not total fuel efficiency per HP.
Thank you for your time,
Old 12-18-2016, 11:00 AM
Air Medal or two
Just by adding 100 HP can not double the loss in the rear end(s)
That would double with every 100 hp in my example .
It would not take long everything would be glowing red.
Old 12-18-2016, 11:14 AM
wdfifteen's Avatar
Y
So it would not be a strict rule ( the loss).
In the OP you were talking about drivetrain loss. The power a turbo uses is accounted for at the crankshaft.
No, a drivetrain is not always going to consume exactly 10% of an engine's output. It could be more, it could be less. Depends on the drivetrain.
Old 12-18-2016, 11:30 AM
Air Medal or two
I was referring to the engine in this instance as it is part of the equation when accounting for loss.
Drive train loss is figured from total HP .
Old 12-18-2016, 12:11 PM
Kantry Member
oldE's Avatar
Think of the bearing and cylinder walls. More force against these surfaces means more friction, heat etc. That is what is eating up your power.
No free lunch.
Best
Les
Best
Les
Old 12-18-2016, 12:38 PM
DanielDudley's Avatar
In a no load system, there won't be a whole lot of loss, and there won't be a lot of increase of loss. With a dyno or a car on the road, when you use that power, you are loading the system.
There is a reason why you can only run so much power through a 915 gearbox, and that is because the load keeps increasing with the power. If you are just using the engine to spin the gears in the air, not much load, and an engine with twice as much power won't do much to the losses, but you won't need to use all that power to spin the gears to red line either, so it isn't really a test of the system.
Old 12-18-2016, 01:44 PM
John Rogers's Avatar
The only way to find the loss of power in the drive train is to take the engine to an engine dyno shop and have them run it. Then put the engine in and take it to a rolling dyno and make some runs with no engine changes. EngHP - RWHP = loss and then you can figure percent.
UncleBilly asked about coolers in race cars and many do not need them but those that are very high speed, high rev or ancient mechanical (901 trans) need a cooler for longevity. In the 914-6 I used to race we had a cooler/pump system to make the ring and pinion last longer and also the same with those hard to find gears. Most serious vintage Porsche racers I knew had coolers in their cars and tranny failure was rare.
Old 12-18-2016, 02:47 PM
The Stick
RKDinOKC's Avatar
Aren't their road dynos that measure the to slow down after the power pull to help calculate friction loss of the engine and drivetrain?
Richard aka "The Stick"
06 Cayenne S Titanium Edition
Old 12-18-2016, 10:30 PM
White and Nerdy
Tervuren's Avatar
Generally, for car's, HP is measured by OEM's as "Crank Horse Power", this is the horse power measured at the crankshaft.
Since taking the engine out to measure isn't often practical, most owners, and tuners, measure Wheel Horse Power, this is the measurement taken from the driven wheels driving the dyno. The 10% estimated loss figure, occurs from the engine at full power in top gear, and getting that power to the dyno at the wheels. You are confusing the number used for transmission loss - the difference between Crank HP and Wheel HP, for the loss in the engine system itself.
Losses involved in the engine itself, is much much much higher than 10%!!!!
When it comes to modification to an engine itself, you can increase crank HP, by decreasing the loss you are confused about. Reducing the restriction of the exhaust, by changing from crimp bends, to rolled bends, increases horse power, and decreases loss.
In take side modifications, are a little different, in that they allow more air flow in, but not always at an increase in efficiency, if the exhaust side can't match the new input, you probably still get more power, but drop efficiency.
For my 944's, I prefer to modify in ways that focus on lowering losses, reducing crank case windage, removing exhaust restriction, etc. These have minor gains, and the gains, are from making the system more efficient.
So the reason you think we are dense, is that the 10% number you pulled, is attributed as a normal loss for a manual transmission car from the crankshaft, to the wheels, when under full power in top gear. We see that number, and translate your first post into talking about that, as you mention "engine transmission loss".
What you seem to be speaking of, now that you've made a few more posts, is actually a loss of about 70-80% of the power the fuel is capable of.
When you add the Turbo, more air and fuel is rammed into the engine, so both the fuel and air used, and the horse power, are going up together. It may not always be a direct ratio, but you are increasing the fuel used in order to gain that horsepower, so the loss is increasing with the power.
Shadilay.
Old 12-18-2016, 10:47 PM
Air Medal or two
First - I said I was dense .
I never said you, or anyone else in the topic is /was.
It is truly quite EZ to repeat what we have been told.
I can do that too.
Which again is why I drool along here.......
I do understand that number thrown out for drive train loss is the 15% number.
I was using the 10%number for simplicity, as stated.
My argument (again) is-
Using the 100 hp @ crankshaft figure, it is expected to see 85HP at the wheels, if we insist on using the 15% rule.
Now we pump up the engine to 200 HP it is said we lose15% which will now equal 170 HP , linear, with 30 HP loss.
To me, going linear up the scale, -it gets ridiculous.
A 500 hp will now see 425 @ the rear. with 75 HP missing in losses.
So with the 100 HP we lose 15HP
At 500, we see 425, 75 HP now consumed in the mass somewhere.
That is one HUGE number to eat!
Stuff is going to be glowing red RED HOT right now.
Old 12-19-2016, 12:52 AM
