heat pump/wiring help needed
I'll put this out there to the brain trust for trouble shooting my Rudd heat pump back up electric heat element. The HP is 6 years old, and I replaced a sequencer, now only 1 element will work. Can someone supply me with a wiring diagram for the connections from the breaker to the sequencers to the element, to see if I did screw up something??? The element pack is RXBH-1724C07J. thanks in advance. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 01-31-2017, 11:08 AM
Brew Master
cabmandone's Avatar
the diagram should be on the panel of your air handler.
Old 01-31-2017, 02:55 PM
You would think so, but its not. The heater is a option, and independent from the HP. It's a generic element designed to fit different air handling units. Philip
Old 01-31-2017, 03:36 PM
