variable compression ratio engines
Infiniti is offering it's 4 cyl turbo'd cars with variable compression ratio engines starting in 2018....per Car and Driver.
Just when you think there is no more room for improvements, some new tech comes out! They say the comp ratio can be changed from 8.8:1 to 12.0 in .2 second...giving better mpg and allowing more boost to be added. According to their preview..an eccentric bushing is used on each connecting rod at the piston end. A small ram turns the bushing to control the compression ratio.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 Last edited by stevej37; 02-02-2017 at 05:52 PM.. |
FUSHIGI
Seems prone to catastrophic failure...but would imagine that was accounted for in the R&D.
I think Volvo was messing around with variable compression a while ago. In their system the block itself was on a cam that would move the block/head in relation to the static crankshaft position. Did not hear much about it since.
gary |
Sorry. It was Sabb and their SVC system. Bankruptcy killed it along with the company.
gary |
They never said what the small piston/ram is controlled by. My Honda has var valve timing and it's controlled by oil pressure. I imagine with todays tech, they could prob control it electronically.
Seeing that it's set to be in all their 4 cyl engines, I'm sure it went thru lots of testing.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 |
Bland
Ummm, isn't every engine with forced induction (Turbo / Supercharged) variable compression?
Another way to think of forced induction is variable displacement. At 1 bar of boost, you are burning twice as much fuel and air as at ambient temperature / pressure so it is equivalent to having double the displacement.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
I prob should have said that as..variable compression "ratio" engine ...meaning the engine is able to vary the distance of the piston from the cylinder head.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 Last edited by stevej37; 02-04-2017 at 01:20 PM.. |
This is a better explanation of how it works. I didn't know Porsche has the patent on it.
Porsche patents Variable Compression Ratio Engine Technology - Ferdinand
Max Sluiter
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Same as the Infiniti system in the OP How could valve timing vary the compression ratio?
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 Last edited by stevej37; 02-04-2017 at 06:15 PM.. |
Max Sluiter
![]() ![]() You could also vary the height of the cylinder head which is how a CFR engine works (that is the engine used as the standard test for octane rating). Valve timing- late closing of the intake valve aka Miller Cycle. You push some of the fresh air back out and this gives you a longer expansion ratio than the effective compression ratio, at the cost of some displacement. I have no idea how the extra complexity and mass gives a big enough thermodynamic benefit over the Miller Cycle to justify itself. Personally, I find this more interesting. http://www.thedetroitbureau.com/2017/01/mazda-aiming-to-first-with-breakthrough-hcci-engine/
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance Last edited by Flieger; 02-04-2017 at 07:50 PM.. |
Recreational Mechanic
Saab made one back in the late 1990's and showed it off in 2000. They were going to put it in the 9-5 but that was right about the time GM bought the remaining 50% of Saab and shelved the engine due to cost.
Saab's version used a tilting cylinder head with the goal of matching CR to forced induction boost. Interestingly (and very non-Saab like) this engine used 5 cylinders instead of 4 and used a supercharger instead of a turbocharger. ![]() ![]() ![]() https://en.wikipedia.org/wiki/Saab_Variable_Compression_engine
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing Last edited by Nickshu; 02-04-2017 at 09:08 PM.. |
This is from the Car and Driver Mag
![]() Selectable Squish Raising an engine’s compression ratio improves fuel efficiency during low-load operation, but it can also lead to catastrophic detonation when maximum power is requested. Engineers have long sought to navigate this challenge with a variable-compression-ratio engine, and Infiniti promises to implement its solution in early 2018 with a complex system of links in the crankcase. There’s more than one way to skin this cat, though. German powertrain engineering company FEV proposes a piston wrist pin that passes through an eccentric bushing at the top of the connecting rod. As the bushing rotates, the piston moves vertically relative to the rod, in turn adjusting the compression ratio. The position of the bushing is determined passively by a pair of miniature pistons inside the connecting rod that rotate the cam in reaction to combustion and inertia forces. FEV’s 1.7-liter turbocharged inline-four demonstrator can adjust its compression ratio from 8.8:1 to 12.0:1 in 0.2 to 0.6 second.
An old family friend has been working on that concept for some time (15+ years)
VCREngine He holds a patent of some sort. His has the crank main bearing journals in an eccentric carrier. Not sure how it's actuated.
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
Information Junky
Toyota has been doing this for a while with an Atkinson cycle engine. (Prius) edit: here we go... Quote:
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Available now in the 2018 Infiniti's
Gon fix it with me hammer
The term compression has never been used to describe forced induction. Merc is the only brand that use the term Kompressor as a marketing name for it's superchargers.. but they didn't use the term compression.. it's just a brand name that nobody else used. Turbo/supercharge just forces more air in the chamber And then more fuel is injected via a seperate process. Sure on a physics level, the air is compressed. the Fuel isn't. Not by the Forced induction it ain't. It's just forced induction.. Nobody calls it compressed induction Forced induction is about air only. Compression points to the piston compressing the Air/fuel mixture.
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 Last edited by svandamme; 04-21-2018 at 03:24 PM.. |
The Saab system seems so simple. I assume it hasn't been adopted is that moving all that mass gives a slow response time.
Back at the turn of the 21st century, Saab revealed a supercharged 1.6-liter inline-five engine with a hinged two-piece block. The engine lowered its compression ratio from 14.0:1 to 8.0:1 by pivoting the top of the block, including the cylinders and the head, around a beefy hinge on the intake side. A set of mini connecting rods riding on an eccentric shaft on the exhaust side did the lifting. Since the crankshaft position is fixed, tilting the block’s top changed the combustion-chamber volume and thus the compression ratio. Saab claimed 225 horsepower and a fuel-economy bump of 30 percent over an engine with similar output. Development costs and Saab’s redheaded-stepchild status within GM meant the capital and interest weren’t there to bring the technology to production.
