Cars & Coffee Killer
This is my thought.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Recreational Mechanic
Sent from my Samsung Tablet using Tapatalk
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
At first I thought it sounded like my SC engine with broken head studs. But after having read the details I love the sound of it. A high compression engine for running around town, then drops the compression to handle the turbo on boost.
Gon fix it with me hammer
Just like Variocam and ram and ignition is now varied across the rev range. Think High compression at low revs for low end power then the turbo kicks in and the compression is dropped accordingly. You can fit 1 bigger turbo instead of ninnying about with a smaller one for less turbo lag. and a bigger one for top end boost. You could even opt to turn on HC for initial spool up, then turn it off & use the boost to accelerate, once on cruising speed at the highway, turn boost off in favor for HC for reduced fuel cost at cruise. To be honest the amount of variables now become so complicated that they are probably going to look at Self learning engine DME's running off Big Data. Eg all the engines send their feedback to the DME, the DME will still work closed loop off some basic programming, but the DME's will then send their data to the cloud Big Data will send back optimisations to the DME
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Yes.
And it would be a good idea to avoid the new technology for a couple of years until it got some maturity and reliability (limp home mode )
No left turn un stoned |
hmm, this would be perfect for HCCI engine. Currently, Mazda needs to use low-boost supercharger and spark plug in order to keep combustion in line across whole range. With variable compression they could probably get rid of supercharger.
https://en.wikipedia.org/wiki/Homogeneous_charge_compression_ignition
Thank you for your time, |
The Stick
Not sure, but Mazda seems to be claiming variable compression with their SkyActive technology. I think it is just a variable cam based on engine loading though.
Richard aka "The Stick" 06 Cayenne S Titanium Edition |
With fully variable geometrical compression ratio, HCCI would be the death of small diesel.
To me, the simplest system is the one shown in post #13
The idea of raising and lowering the whole cyl head..seems way too bulky.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 |
The Infiniti gets pretty darn near diesel compression at full efficiency - wow!
David 1972 911T/S MFI Survivor |
