Home AC question
The AC has stopped working in the kids' home. A guy came out and said there is 1 or maybe 2 leaks in the coils in the outdoor unit. He said that he would check to see if it was under warranty, but I'm not expecting that. He then said that he could fix/replace the coils outside for $2k, but it didn't make any sense to do that when they could get a new unit for $2500. What they currently have is a Goodman, my guess is that it's a 3-4 ton unit. That doesn't sound that crazy to me.
Then the guy said that if he replaced the outdoor unit, and the new unit wasn't compatible with the indoor unit, that he might have to replace both and that would run $5600. I've had both an indoor unit and an outdoor unit replaced on a home at two separate times. I don't think together the cost was that high, and I've never heard that the indoor and outdoor units could be incompatible. They have a pretty run of the mill 2 story home with central air and heat. I'm not sure, but I suspect the house was built in the 90s, maybe. I just want to make sure that they don't get taken for a ride. We had a guy that we used when we lived near them, but since we sold the house, we don't have any of the documentation to see who that was which sucks, because we got a good vibe off of them and didn't feel like we got screwed.
Weeee, sounds like a great ride for the contractor. Quick google search shows the Goodman AC units for around $1000.
I have contact with the HVAC trade and can't believe when I hear what people pay for home HVAC. Shop around those numbers seem high.
Rutager West 1977 911S Targa Chocolate Brown |
Yeah, that's what I was thinking. I think we paid about 900-1000 for a new outside unit, but that was years ago. I'm sure we pay more for AC here than you may pay up north because it gets so hot.
Yep, sounds like a potential snow-job to me. I'd get another bid.
As mentioned, you should be able to source a complete 3-4 ton outdoor condenser unit for under $1k (that's with a new compressor, fan, and motor as well). Last edited by Eric Coffey; 02-07-2017 at 05:15 PM.. |
i thought the outside piece was the condenser and the inside piece was the coil.
shows what i know
Chris the more i learn, the less i know |
UnRegistered User
R-22 in the system now?
Contractor is probably selling to a R410A condensing unit and evap coil. Usually the line set is re usable. Usually is a key word here... That quote seems high. Why is it not possible to fix the existing coil? Tube sheet leaks? Fixable. Last time I checked, you could still get an R-22 condensing unit. They come without a refrigerant charge and R-22 is getting pricey.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
UnRegistered User
The indoor coil is the evaporator coil, the condensing coil is located with the compressor and together is known as the condensing unit.
Retired Member
If it's an older type refrigerant (R22) you can get a dry charged unit. That's a new outdoor unit with no refrigerant. You (the contractor) add the R22.
Sounds like he was guessing as to the number or where the leaks were. Try and find a more qualified contractor. Small leaks can be hard to find.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
I believe in the state of Florida now it's illegal to swap out the old unit if it's R22. Contractors have to change the whole system over. Of course, as a mere homeowner...I was able to do an end around.
Old dog....new tricks..... |
Plan B:
My kid needed a complete AC do-over on her 90s built condo. Two contractors quoted $5-6K to upgrade. We found a company doing ductless mini-splits for $1600 installed. She loves it! Quiet as a mouse, excellent cooling and temp control, and electric bills dropped like a stone in August. It is a one BR condo about 1100 sq ft, but they make dual units for 2 story as well. Not for everyone but it worked well for her. Worth a look.
2021 Cayman GTS 4.0L 2020 Macan (dog hauler) |
Thanks, everyone. Lots of good info.
So the R410A must be the "incompatible" thing that they were talking about, although I think they should still be able to get the R22 replaced here, I think.
Edit- nm I started at the top. You've already been told this. |
I think you can still get the r22 outside units but they are not pre-charged. you can convert the inside unit to r410 if you can change the metering device. easy to do if you have a TXV, you just change the head. we had a compressor changed at work, the guy put in a 410 comp that was previously r22. just change metering head and pressure switches. I would also be leery of the "maybe 2 leaks' in the cond. get someone else out there, have them show you the leak. they should either be able to show you with a leak detector or soap bubbles, I put in a new HEIL system at my house. 4.5ton along with new duct. I think it was around 7-8K. I called my AC guy about the R22 to 410 swap they did at work and he said it was OK. I think AC guys are some of the most crooked people out there, not saying all are. they can get away with it because most people no absolutely NOTHING about AC. one of the guys I work with worked on AC before coming here. he said their company made them "up sell" work the customers did not need. I do AC work but not for a living.
goodman is most likely a fixed orifice tube, BUT, you may still be able to remove the tube and put in one for 410.
how old is the unit?
Still Doin Time
Upselling HVAC................. no different than any other consumer item. A/C techs earn a commission on upsells - replacing units is far more time efficient and profitable than fixing older mechanicals.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Just thinking out loud
The last ac guy that came out to the house, used my gauges, and I told him when it was alright to stop charging. A 30 degree drop from outside ambient to inside vent temperature is NOT acceptable. I don't think most residential ac technicians know refrigeration very well.
83 944 91 FJ80 84 Ram Charger (now gone) |
Sounds very high to me as well. Plus if it is more than 10 years old very inefficient compared to new. Doesn't make any sense to not replace the entire system.
In CA our electricity costs are so high that in the OP's situation we would most likely step up and get the highest SEER rating we could afford. And that would include (IIRC) a two speed compressor.
David 1972 911T/S MFI Survivor |
That's not an issue here. I don't think they plan to be in the house that long, and I also don't think they are prepared to pay for the best of the best.
