I cut 5 ac. with a Kubota with 72" mid mount deck. Takes about 2 hours. Also have a FEL, bush hog for cutting trails to tree stands, 60" front snow blower, forks for the 3 pt. hitch. I put about 100 hrs. on mine a year and it does all I want it to do. Can barrow other implements for the 3 pt. hitch from the neighbors. Something that you can't do with a zero turn. A FEL is the best wheel barrow you will ever have! Can even get the wife to cut the grass every once in a while!
Von http://vonsmog.com 73' 911T Coupe, 76' 911S Targa 73'& 80' Mercedes Unimog DoKa 59' Austin Healey 100-6 |
I can echo Von's post.
When I bought the farm here, there was already an old tractor with a bush hog. I bought two diesel mid mounts and put a FEL on one. The mowing deck is 70 inches on both. We mow about 7 acres as well. My recommendation is to get something like Vons has. The larger tractor that came with with the farm also had an FEL. I have never owned a Kubota but have heard great things about them. Here is Jack ten years ago on the smaller MF: ![]() Looking over the FEL: Both still run great at 1600 or so hours each.
1996 FJ80. Last edited by Seahawk; 02-16-2017 at 05:39 AM.. |
Yes, you are authorized to "need" a tractor. A belly mower will give you a much nicer cut than a brush hog. Notice the tires Von has on that Kubota, important for a nice lawn.
Get a FEL, you will use it all the time. I used mine to load a motorcycle into a pickup when I sold the bike last week. New owner was happy not to mess with a slippery ramp in the snow. Check out the "Do I need a Tractor" thread here.
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Duh
Or you could go au natural and get a herd of goats...
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
My tractor thread may be helpful.
http://forums.pelicanparts.com/off-topic-discussions/866682-do-i-need-tractor.html I ended up with a new John Deere 1025r because buying used wasn't much cheaper than a new one and they offer 0% financing. |
Bland
I bought a Kubota M7060 in 2013 and it is the real deal. It handles a 2000 round bale no problem, runs a 14' haybine, a 530 baler, a post pounder, has a 7' bucket on it, and runs a bale buster just fine. I also have an old Ford flail mower I use with it.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
If you decide to shop for a new compact tractor you must compare the way John Deere and kubota set up their hydrostatic foot pedal assy. The Deere uses the tip of your foot for fwd and rev. Two separate pedals side by side. Kubota uses one single pedal, push toe to move forward, push heel to go backward. You cannot push with your heel. It's ridiculous and I have no idea why anyone would buy one after even a short test drive. I own a Deere 2320 and today at work borrowed a new kubota from the rental co next door for some parking lot maint and could barely walk on my right leg after 20 minutes in it.
Or an old Massey Fergy. A lot cheaper and very reliable.
Being a Kiwi; may I recommend 50 sheep instead
UnRegistered User
Pepper agrees with Bill....
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
beancounter
Data Farmer
This business about the forward/reverse pedals is funny because I have one garden tractor with the heel reverse and another with the deere type setup.
The only problem I have is getting in the habit of using one and then switching between the two tractors and screwing it all up. ![]() I'll also add, that I haven't had many fatigue issues with the heel reverse either***. ***One issue I did run into was when I rebuilt the tractor with the heel reverse setup, the return springs are finicky and need to be set up right, or there is too much/little pressure on the pedal and it will not center in neutral correctly. If the poster with the heel reverse is doing a lot of reverse work, especially looking over their shoulder doing reverse 3-point implement work, I would look into either trying to get a better angle on the seat to see if you could get more leverage over the heel pedal, and look at those springs to make sure they are set up correctly. I ended up removing my return springs (f and r) entirely because one was missing and the other was too powerful, and I could not get a replacement of the right tension to keep the pedal centered. Probably not entirely safe, but since I disabled all the other safety garbage, the tractor isn't going to be winning any Ralph Nader awards anyway. It works great now and really does reduce fatigue (My fatigue was from going forward against the full pressure of one return spring without the opposing spring to balance out the forces- and reduce the pressure needed to hit the forward pedal). Call it a poor man's cruise control. Safe? Nope, but I don't think the factory cruise control on my JD is entirely safe either, especially when mowing. All the other tractors with the heel reverse I have owned (with the proper setup)never have given me fatigue issues. It was only when the springs were setup wrong that it gave trouble. Removed the resistance / effort needed goes down. But you didn't hear that from me! addendumendummm.... Upon further deep pontification and serious introspective reflection, I think if someone is going to be doing a LOT of reverse 3 point implement work, that I would give a slight edge to the John Deere setup, but I'm talking about spending 3-4 hours looking backwards over shoulder at whatever they are doing behind the tractor. For predominately mowing stuff, I think it would be a wash. I would say this based on my experience. Results may vary. Last edited by LEAKYSEALS951; 02-17-2017 at 07:59 AM.. |
Information Overloader
The reverse heel is NOT a problem.
In fact, when doing reverse work, the heel pedal is less of a reach. Also, if the pedal is properly adjusted reverse is used as a brake.
Gallatin, Tennessee
Thanks for all the help. I now am looking at Massey Ferguson. I'll let everyone know what I get when I get it.
Dave |
A front end loader FEL is absolutely a neccesity on a small farm. I use mine to load firewood into the truck, or those really large diameter rounds onto my log splitter. I have spread out 60 tons of ground up pavement on my driveways and smoothed it all out(when they resurfaced the road out front), and have spread multiple truck loads of stone/gravel/dirt when we built our horse riding arena. Everyday, I am moving firewood to the house/hay to the horses/mowing 5 acres.
My JD 955 picks up 1200# with the FEL, and many times, I have to mount weights on the drawbar to keep the rear wheels (4x4) on the ground from so much weight in the bucket. |
Bland
Massey's are nice Japanese made tractor. Not as nice as a Kubota but still pretty nice.
I went through an evolution concerning tractors on my property at the time I was building. First I bought a ten hp. lawn & garden tractor with a trailer to haul stuff around. I soon realized it wasn't enough tractor and looked around for a replacement. I then bought an old Kubota gray market tractor equivalent to the B7100 with 16 hp. It had a tiller, blade and a couple of other implements. They were handy, but I soon realized I needed something quite a bit heavier to get things done. So I ended up with a Kubota L frame from around the year 2,000 with a loader and rear deck mower. Nice thing was it only had 510 hours at the time. I sold the mower attachment for $600. So now I have a box scraper, landscape rake, rear forks, and a couple of other things I can use with it, but the FEL is the important thing. It's the tractor I should have started out with, but of course didn't have the experience to know that. I still have & use the small Kubota and love them both.
Marv Evans '69 911E |
