Water cooled
Question for the guys with water cooled Porsches. Ever used a water pump with a metal impeller ? OE has a plastic impeller. Most aftermarket pumps are metal. Internet Chickenlittles say that will destroy your block if the pump goes out. My '08 3.4 puked its pump today and it seems absurd to pay $300 for a pump with a plastic impeller when the metal ones are $75. Soooo has anyone seen a metal impeller chew a hole in the block ??http://forums.pelicanparts.com/suppo...s/beerchug.gifhttp://forums.pelicanparts.com/suppo...s/beerchug.gif
Interesting question. I'm watching with interest.
This does seem like one of those things where a weak spot has been engineered into the system to keep from making a failure more expensive and catastrophic. It's kind of like the convertible top tie-rods that have plastic tie-rod ends. If something happens, the plastic cap breaks. A lot of folks on the Internet are selling metal tie-rod ends. I think I read an article by Wayne where he replaced the motor and several other pieces of the top mechanism that were bent and bad. Maybe a plastic part in the middle isn't such a bad thing. |
Yeah, no data here, but I can see the argument that it's better to have to have a piece of plastic getting chewed up as opposed to a metal fragment.
Metal impeller water pumps have been used as OEM replacements on many different cars for a long time.
I've never heard of a metal impeller going bad and wrecking the block! And we all know the most common failure is the seal. |
944's have always had metal impellers. I don't think I've ever heard of one breaking. Then again waterpumps on 944's are changed every other belt change (60K miles) for peace of mind sake. But they are expensive. $150-400 each. And they are an all day affair to replace for most people. Because they are such an important part of the 944 engine, I'm not sure many people would risk using a water pump with a plastic impeller on their cars.
Then again my Camry has a plastic impeller-ed WP and they break all the fricken time. But they are cheap (about $20) and are a 30 minute job to replace. |
I just searched ebay. Prices ranged from $37.74 to $577.:eek::eek:
For $577 there needs to be some sex involved.http://forums.pelicanparts.com/support/smileys/jump.gif |
Metal impeller pumps are generally not a great idea. At least on the M96/97 (and probably others) engines the other side of the pump housing is part of the engine block. So if the bearing go bad on your metal impeller pump you are chewing a hole in the aluminum block. That's why the factory used plastic impellers...to protect the block in the event of a failure.
Sent from my SM-G930V using Tapatalk |
never seen it on a Porsche but I have seen two case of a water pump with a metal impeller on a VW TDI loose it's bearing and chew up the block a little bit.
Same same I guess. The metal pump failure being higher risk than the plastic pump failure as far as expensive damage. But you are right neither happen often really. All M96/97 gurus recommend preventive water pump replacement so it's pretty much the standard for maintenance on these engines either way. I replaced mine last summer on my 996. After considering both options I went with a plastic pump. The first pump made it 14 years and 22k miles... Looked fine when it was removed. Sent from my SM-G930V using Tapatalk |
For the record my car has around 81k miles. When I bought it in '15 it had 61k. The bolts have no wrench marks so I am thinking it is original. Maybe I can tell more when I get it out. Leaning toward a $100 dollar pump. Definitely not going with a $577 pump.
https://www.pelicanparts.com/More_Info/99710601106.htm?pn=997-106-011-06-M244&SVSVSI=4296 |
I haven’t replaced mine, but I will be going with the factory type when I do. They are better engineers than I am...
| All times are GMT -8. The time now is 06:49 PM. |
