T77911S's Avatar
MB e320 traanny died. coincidence
2000 Mercedes e320 wagon, 240k on it
actual problem:
I thought maybe the oil leaked out so I put in 2 qts of Valvoline oil. nothing to loose at this point. well it still did the same thing, it would not go from a stop and if driving the engine would just rev. I could really smell burned oil when I removed the dip stick to fill it
back story:
about 6 months ago I removed the valve body, took it apart and cleaned it. I could not find an O ring kit for it. also replaced the conductor plate.
put it back together and the tranny shifted better than it has since we owned it.
oil was little low so instead of getting MB oil I put in a Qt of Valvoline that is for the NAG tranny. same tranny but used in fords and renamed.
so last week with all the cold I let the car warm up. when I got in I smelled some oil burning. car still drove fine,
so the wife drives it yesterday and the tranny starts acting up. I thought it was the same old problem of the dirty oil contaminating the conductor plate. (I have drained the several times trying to get the old oil out) this is why I replaced the conductor plate and cleaned the valve body.
what do you think, any chance 1 qt of Valvoline oil killed it?
oil still dirty enough to contaminate the conductor plate again?
Oring problem because I did not replace them?
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 01-10-2018, 04:11 AM
Almost Banned Once
sc_rufctr's Avatar
240k miles is a lot. I really doubt a quart of Valvoline oil would kill it. (About one liter)
If all else fails, I'd bet you could find a decent transmission at a breaking yard.
- Peter
Old 01-10-2018, 04:43 AM
The Unsettler
stomachmonkey's Avatar
I think 240,000 miles killed it.
Well, maybe not the first 239,999 or so but they did contribute to the problem.
"I want my two dollars"
"Brandon Won"
Old 01-10-2018, 05:33 AM
T77911S's Avatar
it ran so strong up until yesterday. not a single slip. launched from a dead stop. never did that until I cleaned up the valve body.
I will check oil level when I get home.
if it is the conductor plate it should have a code, problem is my code reader wont read MB.
much like a guitar amp, they sound the best the ever sounded right before they blow up.
RACE CAR:: sold
Old 01-10-2018, 09:45 AM
greglepore's Avatar
Valvoline Max is approved for mb transmissions-I use it in all my 722.6 boxes on the v12s
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 01-10-2018, 09:48 AM
enzo1's Avatar
??? Won't shift or slow to shift? What exactly is it doing?...
76' 911s Signature Edition
Old 01-10-2018, 11:40 AM
enzo1's Avatar
Does it have a "kick down" switch under the gas pedal?
Old 01-10-2018, 11:44 AM
