Interesting Evaluating True Horsepower and CFM Ratings of Air Compressors
Old 01-16-2018, 12:47 PM
Charles Freeborn's Avatar
Is there a quiet air compressor?
If you put in a box you’ll need to force vent it or it’ll overheat. Look up “Rotary Vane Compressor”. Not cheap, but dead quiet and very high output.
Quincy makes a fine unit. https://www.aircompressorsdirect.com/Quincy-4152002723-Air-Compressor/p10831.html
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 01-16-2018, 04:18 PM
You guys know damn well that California air compressor ain't gonna run no air tools. A air brush or a finish nail gun, that it.
Old 01-16-2018, 05:38 PM
A930Rocket's Avatar
That's the brand I did a search on. Very quiet.
The dry system is less than 100 gallons, so a small compressor that kicks on every so often will work.
Originally Posted by Danimal16 View Post
Have you looked at California Air Tools? California Air Tools
I have this one (which is much smaller than you require):
https://www.amazon.com/gp/product/B00TDNKBMC/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
It is a great little QUIET unit.
Old 01-16-2018, 05:52 PM
Danimal16's Avatar
It fills tires. Not much more. Not designed for heavy use. It is aluminum and easy to transport.
I use battery impacts. For high output I use PowerTank.
Now with all of that said, read the original requirement. Does not include high consumption tools.
Dan
Old 01-16-2018, 07:21 PM
My recommendation? Stay away from oil less. Not only are they objectively louder, their sound quality is much "harsher" than an oil type. I've owned the Makita MAC700 for years, and it's a powerful little workhouse. Decently quiet and trouble free.
Chris
1986 930
1972 911S
1970 911E
Old 01-17-2018, 04:08 AM
Banned
Nonsense....I have a large tank in my garage, and picked up a small tank compressor for flooring projects and wanted something portable years ago. I don't use air tools that require a constant flow usually, so my small tank does great with all my nailers, powerful impact wrench, etc....90 psi is all that matters....rarely do I use my large tank any more...
Old 01-17-2018, 04:27 AM
I have used isolation feet under the compressor which helps. The big improvement I have made is to fab up a hose adapter and use radiator hose (and tube if it is a long run) to pipe the air inlet outside and put a protected air filter outside. That move most of the noise outdoors, which may not thrill your neighbors.
With the popularity of "cold air intakes" I have seen custom intake "kits" at the auto parts store, which might be easier than my solution with radiator hose.
You can also use compressed air or nitrogen in bottles for your dry system but there are some code requirements for monitoring pressure.
1981 911 SC
2013 Mini Cooper JCW
2017 GMC K1500
Old 01-17-2018, 08:17 AM
