Is there a quiet air compressor?
We’ve got a dry sprinkler system in our clubhouse. It has a small Husky air compressor to refill the air as needed. It sounds like a jet engine when it runs and can be heard throughout the bldg.
We are trying rubber feet, another muffler and maybe an insulated box to quieten it down. If that doesn’t work, well look at other compressors, but we want a quiet one. Are there any out there? Any suggestions? |
To my knowledge there are no " quiet " compressors but there are quieter . You don't mention if the current compressor is an oil less or oil type . Generally the oil less are noisier . My best suggestion is small oil type compressor and then get creative on noise suppression in the area that the compressor is mounted . Build a room within a room ? Heavy insulation , double thickness sheetrock ? But keep in mind you would probably need a source for incoming air to cool the unit when it is running .
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
The only way to make a quiet compressor would make it really slow.
At one of my former offices we had air ported to lots of places in the building. The compressor was in a back room up in the ceiling, hanging from four rods on spring mounts. The ceiling tile panel made it pretty quiet. We put in a high quality oil field grade stainless steel ball valve in the bottom of the tank. Just kill the compressor and and turn the handle and drain the tank. It worked great for 25 years. Changing the oil on the compressor was a pain, but not horrible. If you were in that room you could hear it but having a conversation was not a problem. It was an expensive and complex solution, but it worked great. The easy choice is put the compressor outside.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Banned
I think you can get a screw drive compressor that is a lot quieter.
It’s an oil less system located in our riser room, which is in the middle of the building. At this point, there is no way to move it, double the drywall or insulate it.
The sprinkler trade says it should not come on very often. Only if there is an air leak. When it does come on though, it’s very loud. There is a check valve in the system as well. |
Unregistered
Put a silencer on the suction side.
(the shotguns)
have you experimented with acoustic foam and the like?
would be interesting to put a spectrum analyzer in the room and search for materials that absorb the prominent frequencies.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
beancounter
Eastwood is now selling a scroll type compressor that is extremely quiet. Its not cheap but I think its the least expensive scroll type compressor on the market. They sold out of the initial run and are taking orders now for April delivery.
https://www.eastwood.com/scroll-compressors
![]() Quote:
https://www.eastwood.com/eastwood-qst-30-60-quiet-scroll-air-compressor.html Quote:
![]() Quote:
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 01-16-2018 at 06:16 AM.. |
(the shotguns)
Ho
Lee Sheet. That has got to be the greatest innovation in amateur wrenching since the ratcheting wrench.
A quick search shows a lot of quiet compressors. We only need a 6-10 gallon unit. I saw that some were 45 to 60 dB’s. Cheap too...$350 and less.
And if it's $1300 at Eastwood, the exact same unit is probably available somewhere else for $400.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
I have this one (which is much smaller than you require): https://www.amazon.com/gp/product/B00TDNKBMC/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1 It is a great little QUIET unit. ![]()
Dan |
We run a couple of small Thomas compressors on our job. I love them as they are so much quieter then the home depot jobs but they are about 50% more money but worth it too my poor ears.
I have one of these... Shockingly quiet. Great compressor.
1987 535is, 1966 GTV, 2015 F-Type R, 2013 991 C2, 2011 E550c, 2007 997 C2S, 1987 911, 1958 356 1600s, 1956 356 1600s |
Recreational Mechanic
That Eastwood unit looks good but too bad it's only 12cfms. Can't do much with that if you are a home mechanic using air tools or a blast cabinet.
Sent from my Galaxy S7 using Tapatalk
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
Acoustical drywall
https://www.acousticalsurfaces.com/soundbreak/soundbreak.htm Just saw this on a DIY program. Absorbs 8X more sound than normal drywall. Any chance to replace the existing drywall?
Bunch of old cars ![]() |
Simpler to line the walls with sound absorbing material, something like roxul works great. I have similar drywall on the wall shared with my garage. Works, and an improvement but there is more to it than just drywall.
Here's my question about the Eastwood scroll compressor: if the pump is really so badass, why give it a tank only 1/2 the size of a normal compressor? They cite 2:50 to fill the tank, but as a metric, it's interesting but useless - how often do you really fill the tank from empty?
With a 100% duty cycle I would expect it to be running all the time, at least with any high use tool.
