Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
BoxsterGT's Avatar
Porsche Crest Cleaning inside of Fuchs Wheels
I have a nice pair of 69 911 Fuchs deep six wheels, and I want to clean them inside.
Can I use a Baking Soda blaster at low pressure to clean up the road scum that is still on the inside despite brush scrubbing them.
Any cleaning solution work? I am told NOT TO USE P-21S on them.
Len
Old 06-26-2021, 01:32 PM
Soda blasting would work however a decent soda blaster is huge dollars, HF and all the other cheap ones are a waste of time and money.
Old 06-27-2021, 11:07 AM
group911@aol.co's Avatar
I've had luck with simple green and scotch brite.
Thanks,
Bob
group911@aol.com
Old 08-06-2021, 08:46 AM
Is it oxidation you're dealing with or caked on brake dust? Griot's Garage Heavy Duty Wheel Cleaner makes light work out of brake dust, oxidation you're going to want to use something slightly more abrasive like a rubbing compound. Also considering following up whatever process you use with a ceramic coating to have lasting protection.
Old 08-06-2021, 09:30 AM
Bill Douglas's Avatar
I was just about to say that myself.
It's just road film and brake dust. A good detergent and a light rub down with a scotchbrite will work wonders.
Old 08-07-2021, 12:53 AM
The 9 Store
I use brake clean.
All used parts sold as is.
Old 08-08-2021, 05:36 PM
Not on my Fuchs, but I used a wire brush and wd40 to remove the oxidation on my jeep wheels and then I sprayed them with brake cleaner.
Old 08-11-2021, 11:46 PM
I have been using SONAX wheel cleaner plus for years. Not cheap but it works well.
Old 08-19-2021, 08:00 AM
