Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
911 Mania
How to find Bondo repair
I have an ascot green 76S Targa barn find. Rennbow indicates ascot green is a rare color, a five by their rating method. I prefer coupes, but kept the targa because I like the unique color. I have many receipts with the car and it appears there were a few fender benders.
How can I find bondo on the car? I’ve gone over the car with a magnet thinking it won’t cling to bondo, is that correct? What’s the best way to find bondo without stripping the paint?
Thanks!
"When the debate is lost, slander becomes the tool of the losers." Socrates
Old 12-07-2021, 11:44 PM
A magnet will work, there are also other methods such as a digital coating thickness tester.
Obviously a magnet has less attraction as a coating gets thicker. This could be bondo, paint or some other non metalic substance between the magnet and the steel. Digital meters work on a similar principal.
Old 12-09-2021, 03:38 AM
Strip it - that’s the only way to achieve true peace of mind. And if/when you do strip it, document with many many pictures so if/when you sell the car, you can show to prospective buyers.
Old 12-09-2021, 08:01 PM
You’re on the right track. Bondo or any plastic filler for that matter is of course non ferrous.
Even if it was put on rellhitivly thin you’ll feel the difference with a good magnet.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 12-10-2021, 06:49 PM
As noted earlier, a paint meter would be a good way to establish paint thickness as well as bondo and its thickness. Basically a paint meter is measuring the distance between the meter and the base metal so if for example the meter reads 25 mils then you likely have about 5 - 7 mils of paint and another 18-20 mils of bondo/filler.
CURRENT:
2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black
1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue
2024 Macan White, Beige / 2010 Cayenne White, Black
PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey
Old 12-29-2021, 12:33 PM
