Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
need info on fender rehab
rear aluminum bumper had corrosion.
Has been sanded and ground out.
Do I use or should i use Epoxy then Bondo?… then acid etching primer then paint?
Or is there a better procedure or products?
Old 04-03-2025, 02:18 PM
You don’t need acid etch primer, it’s for bare steel generally.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 05-24-2025, 04:57 AM
dkbautosports.com
962porsche's Avatar
you epoxy primer then use a quality body filler ( not a fan of bond brand filler ) then epoxy primer , prep and top coat.
Old 05-31-2025, 02:14 PM
Tags
bondo , bumper repair , paint
