Drying time epoxy primer
Hi, I've used some epoxy primer on my car (bare metal). It seems I got the hardener ratio wrong, as it has been drying quite slowly. Instead of the approx. 5 hours, it took maybe 20 hours. Is this a problem and should I remove and redo it or is this okay?
Many thanks Dennis
_____________________________ 1972 911 2.4S Black on Black, Recaro's, SSI, MFI, dual pipe exhaust, currently running in after engine rebuild! |
Hi all, any advice from an expert?
Regards Dennis
This probably isn't what you want to hear but I'd call a paint supplier that sells the particular brand you used and ask them. They all have reps that stop by. They can get an answer for you.
O2 In Sully We Believe |
Just like Mark said, I also thought somebody else might have a better idea.
Remove and re do, don't want to start with a bad foundation.
"EVER SINCE EXCUSES WERE INVENTED, EVERYBODY IS PERFECT" http://axiom-motorsports.com/ Rudy Ruano, Operations Manager. Joseph Toliva, guy who signs my check |
