Rennch on YouTube
Can I make touch up paint out of my base/clear?
I have extra basecoat/clearcoat, and I need some touch up paint for the RSR. Can I make some somehow?
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
Just how much touch-up paint do you need? Is it just for small rock ding chips, and small scratches? If so, you can use what you already have, just use a small enough applicator to only fill in the defect, let the base coat dry, then do the same with the clear. The biggest flaw in doing it this way, is the clear won't have the hardener, and may take a bit of time to harden and "dry" As far as some paint just for small touch-up on small blemishes, get you paint guy to mix you up a color test amount in single stage paint. It will only be an ounce or two, but it will be the proper paint match, and it is a one step, touch-up repair. Plus, if you are friends with the paint guy, most times they won't even charge you for the "test color sample" in a small container... at least my paint man does not charge for this service. Good luck!! Tony.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Rennch on YouTube
Well, that's what I'm thinking... a test color sample. Do I need to dilute the paint with the reducer?
One rock chips and the like, I just use the touch-up paint as is, no reducer. The tiny areas that are getting the attention, seem to work fine without the reducer, but... I am only talking about very minor type chips or scratches, nothing that would really require and type of body repair first.
for small paint chips, use just the base paint, no reducer is needed, but ok to use the reducer, too.
let it dry overnight, cover with clear nail polish! |
Certain paints require catalyst to dry completely. Thus you will have to get a colour match made up in a pre-cat or straight paint. Could end up kinda gooey in some cases.
