Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
surface rust.... leave on for now?
I am new to the forums and just acquired a 1973.5 911 (CIS) Targa. The front fenders are off the car as well as the doors, hood, and rear lid. The previous owner planned to restore the car but never finished the job and let the car sit unassembled for 15 years.
Overall, the body is in good shape with a few rust-through areas on the door rocker panels and on the chassis where the passenger side front fender panel bolts on (just in front of the passenger door). No dents or collision damage anywhere.
Anyway, the front fenders are off the car and evidently the previous owner sanded the paint off the exterior side. There are is now a considerable layer of surface rust (no rust-through areas). Budget concerns won't allow me to paint the car this year. That will be next Summer's project. With that in mind (and knowing next to nothing about body/paint work), should I try and sand down the fenders to metal right now myself and prime them just to stop any more rusting action? Or can the paint shop I take it to next year take care of this then and no further rust be a concern?
Old 05-04-2010, 04:40 PM
Slugwerks's Avatar
I'm probably about as much an expert as you are, but I'd get rid of the rust and get a self etching primer on there to prevent it from getting worse.
1969 911 E Under Construction
Old 05-04-2010, 10:57 PM
Bird. It's the word...
Fishcop's Avatar
If nothing else, keep it all dry and use Picklex20 on it.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 05-05-2010, 01:29 AM
rw7810's Avatar
Like john says and put on a coat of epoxy primer if possible. If kept inside, this would be best.
Robert Williams
70' 911T
Old 05-05-2010, 08:00 AM
Tim K's Avatar
Here is a link you should find helpful:
http://forums.pelicanparts.com/porsche-911-technical-forum/262049-metal-conditioning-epoxy-priming-101-a.html
Welcome to the board.
Tim K
Old 05-05-2010, 10:50 AM
dkbautosports.com
962porsche's Avatar
send the panels out and get them blasted then spray an E-primer on some places that do blasting will also prime them too if you want . there is no primers made that hold out water . so in no way should you let them sit in any rain or even a damp shop for any amount of time . i would opt for an etching primer not an epoxy primer . an etch primer has a higher chromated base than and epoxy based primer . the down side is that you can't use a polyester based primer like feather fill over it . so if there are alot of pits you will have to skim coat it with a product like icing or metal-glaze . thay are very light weight body fillers meant to fill in pin holes in heavy weight body fillers .you might call it bondo . but bondo is a brand not a product that would be like calling every car a ford !
Old 05-05-2010, 04:28 PM
HarryD's Avatar
Why take a chance for things to get worse?
I would wire brush the rust off, hit it with a rust killer (Rust Mort, Naval jelly etc), then prime.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-07-2010, 09:40 PM
